Results 1 to 6 of 6
Thread: How do I listen to my Ipod????
    Sep 2003
    I have a 2003 bmw with a cd player.. i want to listen to my ipod without having to replace the deck and lose the use of my sterring wheel controls. Is there anonther way to hook up my ipod
    I ve tried all the FM transmitters...they suck..
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    Quote Originally Posted by axlrose
    It is a difficult task using the factory deck. Really i think that your only option is to use an FM Modulator, but like you mentioned, all of the ones I know of sound like crap.
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    It depends on how much the FM modulators costs. I have seen some which costs about 75 bucks and they are great. The ones from RadioShack and Bestbuy sucks.
    You get what you paid for.
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Unfortunately, the only way to listen using a stock head unit, is to use a FM modulator. FM modulators won't give you the same quality as a headphone connection to a AUX input on an aftermarket deck, because FM frequency response is more narrow than say, what you would get from CD. Frequencies audible to humans are 20Hz-20Khz. All of these frequencies are audible in a good home or car audio system. FM, on the other hand is like 50Hz-12Khz. The reason for this is bandwidth and power conservation for the transmitter.
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    you might be able to use a cd-changer control adapter if you gone cd-changer control on your hu
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    You need either this:
    http://www.sounddomain.com/sku/PERBMWALPX
    or this:
    http://www.sounddomain.com/sku/PERBMWPILA
    Depending on which Model head unit you have in the BMW. Then you can just run a long 1/8" jack to the front and there you have it...
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
