Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Easiest way to tap a 12V accessory line
  1. #11
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    I bought a litte device at auto zone today called an add a circut, It allows you to add a new, seperately fused circut without having to do any wiring.
    The first fuse is for the original attachment and the second is for your accesory.
    What do you people think of it? I plan to run it off the cigarett lighter line, as I never use it for anything other then the car computer.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
  2. #12
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Quote Originally Posted by fluffy2097
    That device looks cool. I'll get that to run a line to my shutdown controller.
  3. #13
  4. #14
    Jan 2002
    Long Island, NY
    That was the item that caused reboots and loose connections in my last CarPC.
    I'd rather just shave some sheilding off with a knife, wrap the wire around and apply some solder and then wrap nicely. Much cheaper and you won't have a loose connection 4 sure.
  5. #15
    Constant Bitrate dexy's Avatar
    Jul 2004
    NY
    You can also get a service manual for ur car at the Honda/Acura delear. Its like 35bucks. Its a must have for a do it urselfer, it shows everything, such as what each wire means in ur car. So u'll never be scared of opening stuff after looking at it. I think u can actually call in the order. I forgot the 1-800 number. Or check out honda-tech.com or hondahookup.com forums, U'll find more than enough
  6. #16
    Jan 2002
    Long Island, NY
    Kinda late, but that's ok.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  7. #17
    Jul 2004
    Minneapolis
    Two ways to do this: professional and DIY. Pro is gonna be solder and tape, DIY is gonna be some sort of tap like the one pictured at your fuse box. Although I only make connections one way in my car I'm sure the fuse box tap will be adequate for many. Just be smart about it. I would recommend putting a bit of e-tape on the top of the fuse as those terminals are exposed and worst case scenario you might find that rubbing up against some metal.
