Shutdown Start Up circuit question
with the DSSC Startup/Shutdown Circuit how exactly does that connect?
does it go DC in and DC out? if so it can only be used with a DC/DC power suppy? or can it be used with an inverter somehow?
i'm looking at this board
http://www.dashmatics.com/product_in...roducts_id=50#
if i were to go with an inverter would i still need this?
All this does is monitor your ignition line. When you turn the car on, it flips "switches" (relays) and tells the motherboard to start up. You'd still need a power supply. The positive line from the power supply would connect to one of the relays.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
