Raw Wave
You might be best off with an Epia board. They're nice and small (17x17cm), low power, but still reasonably fast for what you might need.
For display, if you are going to be having any kind of text, then you will want a VGA display. Such displays would be from DSCustoms, DigitalWW, Xenarc etc. The cheap LCD's you find on Ebay and the like (such as for $100) will not be VGA, and will only have composite in, which will be very bad for any type of text, and are normally STN (which means low viewing angle, dim, washed out colours).
Having touchscreen might solve any input issues you might have, however if you will not need any input, then just get one without touchscreen, which will save you a few $$.
For power, you should be able to find a dc-dc psu which will take 24Vin, otherwise, you may wish to use a voltage regulator, and a dc-dc psu that takes 12Vin. The Epia motherboard is ATX, so what you say you've found should be OK.
As you will be offroad, I seriously recommend you look for a laptop (2.5") hard drive, as they will be much more shock resiliant than the standard desktop (3.5") hard drives, and will also consume less power, and put out less heat.
As for casing, I would not recommend a totally sealed enclosure, as even though things will be low power/heat, they will still put out some heat, and if there's no way for the heat to escape, then you will fry your components reasonably quickly. Even just a small 40mm fan on both ends of the case to move some air through (doesn't have to be that much air, no need for a tornado!) will allow the heat to be dispersed
Good luck with the project, and if you need any more specific help, chances are someone has done something similar or identical with similar/same components, the search button up the top will be your friend
Welcome to the forum, also
Garry
when i was in colorado i could barely keep my carputer running on even a 3 or 4 rated trail, i ended up using my laptop more as it didn't have hard drive crashes left and right.
it is nice to have the 3D Topo up, however I found myself not using it a whole heck of a lot, I just looked at the trail before i left the hotel and then used a handheld gps to track and uploaded my track to my computer afterwards.
Also, for the screens, make sure you have it mounted VERY securely, my old one was only mounted on the bottom with a bolt and well it vibrated so much that it cracked the housing all up to hell
radmanrugg:
Nice Pinzgauer! My brother wants one really bad
For your power supply needs, I just thought that I'd note that OPUS solutions that a lot of people (including myself) are using ery happily has a 24V model as well as the 12V version. I know they have the 24V in 150W but I dont know if they have it in the 90W.
If you are using two or four regular 12V cells instead of a real 24V battery (I think most Pinzgauer people are running two Optima Red/Yellow's in series now) .. then you can use a regular 12V supply by coming off of only the first battery in line. Still, to simplify things, running a 24V PSU would be better.
If I were you, i'd probably go with a MiniITX system.. It can take the heat better than most other systems and has fewer parts/peices to vibrate off. You'll probably want to use a laptop HDD and shock mount every single thing inside your enclosure very well. Freestyler seems pretty pessimistic about running while on-trails, but I think it would not be that hard to get whatever you wanted to run able to stand the heat/vibration in the most extreme conditions...
MY CAR IS FOR SALE!
See My Project Page for Details - 2003 BMW E46
///M3
Custom Dash Monitor Housing - OEM Fitment
Custom Overhead DVD-ROM Housing in Headliner
BMW I-Bus Integration
My homepage with many other fun projects!
it's not "vibrations" as you put it
imagine your potholes in tx (if u have them) and then multiply the bump by like 100 sometimes, personally I would suggest against running a full desktop drive at least, u might get away with a laptop drive, my laptop was in my mom's lap if we had it on
yea that would work, some kind of custom fab'd shock system
would u have a prob with resonance? like as in having undamped
movement?
Raw Wave
You can use the shock absorber units as found in model cars. They come with springs as well as dampers filled with fluid just like in a real car
I thought about doing this on the whole PC, perhaps with 6 shock absorbers enough to hold the whole unit in place...dont have time to do it yet. My setup should only be about 1Kg or so.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
