Results 1 to 10 of 12
Thread: battery
    Newbie jettamasta's Avatar
    Sep 2003
    battery
    i am planning on using the battery under the car to run the car only, and put a new battery in the trun to run everything else. how difficult is it to rewire everything from old battery to new if i am compleatly striping the car to put in my roll cage?
    Aug 2003
    HOME CHICAGO, NOW IN Greensboro
    You mean to say that you will have a battery to crank and provide ignition and rest of the stuff, heater, lights , radio on the other ?
    If so how ill you charge the other one and if so what is the benfit?
    There is a kit to move your battery from the front to the back, which includes wires and may be a battery clamp.
    ALIBABA - I30 99
    Nemiah M10000, C134
    DVD, 40Gig, 256MB DDR
    GPS, OBD 2, Reverse Cam
    Mute on stereo w I300 car kit
    Liliput 7in w usb touch screen
    Direct connect with BOSE-CD changer
    Sep 2003
    i am going to need 2 batterys for all the stuff i am getting for my car, and if i could put both in the trunk that would be perfrect. if i hooked both batteries in parralel is that how u are able to power more stuff? i am prety sure but i dont want to ***** it up. got any links to the kit site?
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    A battery Isolator is the answer. It is a couple of large diodes with a big heatsink.
    You hook the juice to it and each battery. The batteries get charged, but one battery cannot drain the other one.
    OR you can hook both positives together (like in a diesel truck)...or parallel like you said.
    The point is you get more amp/hours, but the same 12v.
    Dec 2001
    Columbia, Maryland
    you also need 2 of the same type of battery, and the from the same "vintage".
    Aug 2003
    you wll need to use a bigger alternator in terms of amps if you have gagets which hog power....
    ALIBABA - I30 99
    Nemiah M10000, C134
    Sep 2003
    would both do the trick? the battery Isolator and hooking up in parellel? what is the difference performance wise between the two? and i know about upgrading the alternator and have already forund the one i am going to get.
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    two diff things.... two different jobs.
    Battery isolater(well the one at DSE)
    -prevents the 1st battery from sucking the 2nd while cranking.
    -prevents the 1st one from being flattened, when car not running,
    allowing only current from #2
    -charges both batteries when the car is running
    (someone correct me if i wrong)
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    I would run them in parellel but the thing is with that they have to be the same battery or have the same crankin amps or something. I really cant remember what has the be the same but to be on the safe side i would get the same bat.
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    Aug 2003
    isolaters mean can be two diff types of batteries. like hav ur normal
    starter battery, and a deep cycle battery.
    cant reaaaaaaaaaally see y u would need two batteries....
