Results 11 to 20 of 25
Thread: operating frequency
  1. #11
    Oct 2003
    usa
    i could just eliminate the input rectifier. and run 120 dc to that. i have a 120v dc motor i could just belt to the engine. thast would probably be too dirty. wait. u meen after rectifacation, the voltage from the rectifier is 300v!?!? that would n't be much of a prob tho, just finding the right transformer
  2. #12
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I am not the smartest guy in the group, but if you have a US system that is designed to run off 120vac mains, then when you rectify that (diode bridge) to DC...you get 120vdc (minus a bit for heat transfer)...The European guys can play with the 250v.
    I don't have any idea what a 120vdc motor could be used for, but if you had one, and put a load on it, (with a little rewiring)it would make a dc generator...but it would really be crappy at the job...
    Just get one of those DC-DC power supplies.
  3. #13
    Raw Wave
    Jun 2003
    Yes, that can work...but aint we going back to the inefficiency situation again?
  4. #14
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by DodgeCummins
    Nope, 1.41 times for a full wave bridge rectifier (less a little bit for voltage drop across the doides - the heat transfer you talk of). Don't forget the 120vac is an RMS reading, it peaks higher than that. Same for 250vac.
    See here for more info about bridge rectifiers:
    http://www.mitedu.freeserve.co.uk/Design/dcpsu.htm
    So 250v ac turns into around 350v dc, and 120v ac turns into nearly 170v dc.
    Rob
  5. #15
    Oct 2003
    usa
    so it should manage at 120 dc
  6. #16
    Oct 2000
    DFW area
    Quote Originally Posted by Rob Withey
    Rob
    Yes, the resistance across the diodes causing the heat transfer, and the voltage drop.
  7. #17
    Raw Wave
    Jun 2003
    Ok but how you gonna keep the power to your pc if you stall the engine? Its not gonna be easy working with high voltages
  8. #18
    Oct 2003
    usa
    well, if my engine stals, i got bigger problems than no music! i doubt my engine will stall and i probably won't use the 120vdc generator, ill use a transformer running on pulsed dc. then rectify that and feed it past the rectifyer on the psu
  9. #19
    Apr 2000
    Bedfordshire, UK
    Diodes are semiconductors, they don't have resistance. Specifically, if the current flow increases, the voltage drop does not increase linearly as with a resistor.
    Rob
  10. #20
    Raw Wave
    Jun 2003
    Sure they still have internal resistance. Thats one of the reason that limits the amount of power it can handle. A high power semiconductor do have very low internal resistance when they conduct...so it enable them to pass higher currents
