Results 1 to 10 of 10
Thread: music without head unit
    Nov 2003
    yeh this is my first post. i'm new. i'm starting my car pc project and i've gotten everything. i just wanna know how to get music without a head unit.
    Low Bitrate wylie-c's Avatar
    Oct 2003
    Canada
    You need an amp, and you run the computer to that and use the software volume control.
    Nov 2003
    okay i have a Rockford amp, one of those new 1500 watt ones. whats volume control?
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    LOL. Stops your ears bleeding.
    4x4 in a turbo stylee.
    Nov 2003
    Australia
    Quote Originally Posted by Tinh2
    the volume control is the same thing you use to adjust the volume in windows.
    May 2001
    Dunstable, England
    Mk3 of my carputer didn't have a head unit and I used the volume control of Windows to increase/decrease the music.
    Worked fine!!
    Hope this helps.
    Best regards,
    Darren Thrower
    http://www.percyt.com/mp3player.htm
    Nov 2003
    okay you say you plugged your computer into your amp..
    then where do all of the other wires go.. i mean the wires that are supposed to connect to the headunit. erg i'm confused.
    o and this is the amp i have. can anyone tell me if it works with the computer to amp thing with no head unit:
    http://www.bestbuy.com/site/olspage....oryId=cat03085
    thnx
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    thnx
    Okay, do you already have the amp connected to your system? Is it powering all your speakers? If not, you're going to need to pick up another amp. It looks like that amp will only run two speakers (or one, bridged). If you've got four speakers and a sub, you're going to need at least a three-channel amp as well as that one you've already got.
    Normally, RCA's go from your head unit to the amp, then speaker wire to the speakers. Now, you want to run RCA's from your sound card in your computer out to the amp instead.
    Regarding wires, what other wires to the HU are you talking about? The power and remote wires? You can just ignore them, cap them or tape them up to prevent shorting.
    Good luck, and have fun.
    Kris
    Newbie hklomann's Avatar
    Nov 2003
    Germany NRW
    have a look at my project : prototype at work Volvo s60 D5 Intel P4
    used different testing setups
    a simple line mixer with headunit
    or 5.1 sound from mobo or 5.1 sound from maya5.1 usb soundlevel controled by griffin powermate
    Nov 2003
    damn might as well get a head unit then.. yeh my amp is only 2 channel. haha now i'm debating to see which way would be cheaper.. head unit or another amp..
