Results 11 to 20 of 21
Thread: Powering amp indoors?
  1. #11
    Low Bitrate doig's Avatar
    Apr 2003
    Melbourne, Australia
    Do some digging - its possible to mod an AT power supply to supply 13.5v at 20amps. use in conjunction with one or several batts and there you go. Very cheap way to do it
  2. #12
    FLAC guitar333's Avatar
    Jun 2003
    IDAHO
    yeah figure on how many watts youll be pulling, eg 200w rms amp 200/applied voltage (12v?) 200/12 = 16.67A, so Im sure youll need a fairly large psu if u decide to go this route
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
  3. #13
    Apr 2003
    I said a modded AT psu - all the power gets dumped into the new 13.5v line.
  4. #14
    Jun 2003
    IDAHO
  5. #15
    Apr 2003
    sigh - look at me, cant even make sence of simple posts anymore!
    I guess thats what Uni exams do to me...
  6. #16
    Jun 2003
    IDAHO
    Quote Originally Posted by doig
    understandable
  7. #17
    2nz
    2nz is offline
    Newbie 2nz's Avatar
    Nov 2003
    SoCal
    Running all/part of your auto soundsystem indoors
    Sure, you can run your system off a battery charger - BUT, you must also use a battery too! That is, you take a battery in working condition to run your system but run the charger during it's use and afterwards to charge it back up. You may encounter some buzz from the battery charger which requires filtering. Better to get a dc power supply to recharge the battery, or one big enough to run the whole system - 60-100 Amp or so. Subs take lots of amps to push at low freqs.
  8. #18
    Newbie NEO_0690's Avatar
    Oct 2003
    San Jose, CA
    Thanks for the replies but i gave up on the idea, i get my truck back tomorrow anyways, lol
  9. #19
    Constant Bitrate Suprapc's Avatar
    Apr 2003
    Scott, La
    You could also use a ATX powersupply. To turn one on connect the green wire to one of the grounds.
    Check to see the amperage of the +12v line is sufficient to run the amp if you go this route.
    2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
  10. #20
    Jun 2003
    silicon chip october 2003:
    20A/13.5V supply from an old PC.
    is that what u read doig.
    so if we follow guitar333 example 200/12 = 16.67A
    20A is enough
