Results 1 to 10 of 10
Thread: In Need Of Everyones Oppinion! PLEASE (Newbie)
    Low Bitrate pc832's Avatar
    Nov 2003
    San Diego
    Exclamation In Need Of Everyones Opinion! PLEASE (Newbie)
    I know Iím a newbie about to make a large request but I would like to know what you veterans think. I'm considering some equipment and would like everyoneís opinion before I fork out $1000.00+ on the stuff.
    Please let me know what you think are the best systems/equipment that I am listing below by responding something like 1+4+8 etc.
    Cases/Motherboards:
    1. http://www.cartft.com/catalog/il/50
    2. http://us.shuttle.com/specs_access.asp?pro_id=284
    3. http://www.essencompu.com/nupplysingar.asp?ID=3484
    4. http://www.idotpc.com/TheStore/Deskt...836&Cate.id=19
    OS:
    5. http://www.mediaengine.org/index.php
    6. http://www.carplayer.com/
    7a. http://www.microsoft.com/windowsxp/m...s/allinone.asp
    7b. http://www.gnetcanada.com/digitaldash.htm
    Monitor:(touchscreen)
    8. http://www.spysupply007.com/LCD_Scre...arc/700TS.html
    9.http://www.savinglots.com/lotprod.asp?item=AVDW6210
    Thanks in advance.
    I Failed to mention that this will be an install within a '02 Ford Sportrac.
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    althou no veteran, would suggest this (logically)
    From the choices you listed and if you have space in you car, I would suggest 2-5-8
    If you don't have that much space and/or wanna mount the comp under the seat go 3-5-8
    BUT if I were you, I would get a mini ATX mobo, custom case it and mount it under pas. seat. I personally find CarBox software the easiest to use, but many people like Media Engine, etc. So thats a matter of taste. For monitor search on ebay for Lilliput - cheapest.
    Overall, just search for everything (lcd monitor, software, motherboards, touchscreen - whatever makes sense) and you should come up with lots of answers. Sometimes even too many,which makes it very hard to choose
    Current Status: For Sale
    Specs
    - 1.5Ghz Toshiba Laptop (available - no screen)
    - Indash Motorized 7" VGA TS
    - DeLorme GPS (sold)
    - Power Inverter (sold)
    - Pioneer HU (sold)
    Nov 2003
    San Diego
    Thumbs up
    Thanks carabuser.
    Just the kind of info I was looking for and i'll look into the ATX mobo.
    Variable Bitrate telekineticfool's Avatar
    Mar 2003
    AZ
    I vote for "miniITX in custom case with opus-5-8" :-)
    MP3 MR2 (click here for details)
    Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
    Software: Windows 2000, Media Engine 2.0
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    Quote Originally Posted by telekineticfool
    dito that telekineticfoo
    BossTone74
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    Quote Originally Posted by pc832
    Why do you want to pay GNET when you can get the exect same thing for free? Search for AiPC
    As for car computer itself, I use my Espresso PC and I recommand those PCs. Either Espresso or Cuppuchino PC since they run on 9-15v DC and they are one piece unit and have everything you need built in. Cheaper to build and easier to carry around if you need to.
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Nov 2003
    San Diego
    Thanks guys for your suggestions. I actually expected my request to somewhat ignored.
    I've decided to go with the following for now:
    • VIA EPIA Nehemiah M10000 1Ghz All In One Motherboard
    • 512MB 266Mhz DDR SDRAM PC2100 CL2.5
    • 60gb slim hdd
    I will test this out until I fork out more $ for the LCD and such.
    Please keep any other suggestions coming.
    *On a side note...Being that this is going to be an install within a 2003 Ford SportTrac and I have yet to see one done. I'm thinking of documenting my progress and posting it at some future time.
    Aug 2003
    CA
    looks good. do you have an existing audio setup there already(not the OEM, something like amps, sub etc.)?
    Specs
    - Pioneer HU (sold)
    Nov 2003
    San Diego
    Quote Originally Posted by carabuser
    I've got the Pioneer premium upgrade (by mistake at no charge) with the truck.
    This systems has a small amp already installed behind the rear seats hooked up to a 6" sub.
    I'm definately going to upgrade this once I'm sure my hookup works.
    Although money is not really an issue I still don't want to burn it all at once. I'm verry content making baby steps with this hookup but will hopefully have it all within a month.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    About the software, there are so many free/excellent solutions. Seraphs aiPC, coyote's MediaCar, anything under the software section, i think FrodoPlayer will soon make it's debut. Media-z runs under linux, and if you plan on running linux there is the DashPC software, along with myth (i believe linux users?). In short, there are many free options that are just as good if not better than ones that charge.
