Results 1 to 9 of 9
Thread: Sony Vaio install
    Nov 2003
    Boston
    Question Sony Vaio install
    Hi All,
    I am interested in putting a Sony Vaio notebook in my glovebox. The reason being its compact, enclosed, fast, stores a lot, and has a dvd player. Plus, I already have it so I won't need to buy a motherboard, processor, etc. I have a 5" LCD screen in my dash that used to connect to my PS2. It is not a touch screen so I need a little help from you all.
    I need to be able to have the laptop power up when the car starts and hibernate or shutdown when the car is off. I also need some way to control the laptop without having it open. I thought of using a touchpad for that. So how can I set it up to startup and shut off?
    Nov 2003
    Boston
    that didn't answer my question. i know how to hook one up to the battery. However, when the laptop turns off or hibernates, a button needs to be pushed to turn it on. My laptop will not start right up if i plug it in and it won't shut down if i unplug it.
    Variable Bitrate telekineticfool's Avatar
    Mar 2003
    AZ
    Ok well do a search.
    I got five good results by doing a search with the words "Laptop" and "Power"
    highlights:
    laptop carputer - noobie needs help :)
    psuedo start up controller, help :)
    MP3 MR2 (click here for details)
    Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
    Software: Windows 2000, Media Engine 2.0
    Jul 2003
    Earth
    i saw this post and i have to say i f***ing hate vaios.
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Hi!
    I actually drilled a hole in my laptop body, attached two wires to the points on the motherboard that complete the circuit to start up the machine. I then put a momentary contact switch in my center console and use this to start the laptop.
    I don't hibernate the laptop, I turn it off and then on when I need it. I know that hybernation in XP requires a keypress to activate. At least I think so anyways. If you figure out a way to use hybernation while the LCD is closed, letme know how.
    Quote Originally Posted by driver850
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I unsoldered the original reset and power switches, then ran wires from them to my switches in the dash.
    FLAC chut's Avatar
    Jul 2003
    ok, i just figured it out. On XP you can uncheck the require password on resume from standby under the advanced tab. This also works from hybernation on the laptop i'm writing this on.
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    Vios have overheating issues. Probably not smart to stuff them in a glovebox.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
