Results 1 to 10 of 12
Thread: laptop or a mobo and touch screen solution?!
    Mix
    Mix is offline
    Nov 2003
    hi!
    I wonder what is better to use a separate mobo and lcd touchscreen or a laptop.whatīs the good things about the laptop and whatīs whit the mobo and touchscreen.I think that itīs easyier to upgrade the separate mobo,a laptop must bee replaysed when you going to upgrade,the power solution is easier whit the laptop tought.come whit your opinions?!exuce my bad english hope you understand does anyone know where i can by a 12v ATX power supply to finland,are there any stores i germany prehaps?!
    Nov 2003
    Orlando, FL
    Quote Originally Posted by Enforcer
    ATX in germany, do a search for ACE 916V.
    laptops are limited, go for seperates.
    I disagree...
    Laptops are shock resistant, they have everything you need already built in, and if you get a port replicator, you can take it out very easily without worrying about unplugging everything.
    I'm still very much considering this route.
    Variable Bitrate telekineticfool's Avatar
    Mar 2003
    AZ
    I am going to have to disagree with your disagreement...laptops are more limited than conventional component pc's...the only exception is a port replicator that has someplace to sit, and even then you have power, shutdown/startup, and space issues. At the moment, a mini-itx/opus/lilliput is a nice flexible $500-600 touchscreen solution for an in-car pc. This of course assumes you are starting from scratch...if you need to use stuff you already have (ie, laptop) that changes the game.
    MP3 MR2 (click here for details)
    Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
    Software: Windows 2000, Media Engine 2.0
    Constant Bitrate blicky_1's Avatar
    Sep 2003
    North Hampshire, United Kingdom
    Quote Originally Posted by telekineticfool
    I think it's a great idea to start with a laptop if you have one. I know the issues of startup/shutdown but i'm using one in the car at the moment for testing and only have to press the power button on once at the start of the day (leave the DC adaptor on when not in the car) and shutdown with the touchscreen. With this my laptop is always on and just the screen turns on/off with ignition meaning it is ready straight away, no delay.
    They are limited but if you can pick up a cheap one (busted screen?) with all the bits on it you need then they are a good buy to start you carputer project.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    At first I was going to put a laptop in, but had issues with it, most was the speed of the processor, and I didn't really want to use an expensive laptop for the job.
    also I knew the project would outgrow what ever I started with and a Desktop style is far more flexible to upgrade and the suchlike than a laptop.
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    ...it all depends on what you want, and how much you want to pay...and how reliable you would like your setup.
    Mar 2003
    AZ
    ...and finally, what you already have on hand to work with.
    Oct 2000
    DFW area
    Yup
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    surely that's between him and his hand?
  1. FS: TONS OF STUFF (lcds, touch screens, boards, etc)
    By W6-Ryan in forum Classified Archive
    Last Post: 07-06-2002, 01:46 PM
