Results 1 to 10 of 16
Thread: why use a shutdown controller???
    Nov 2003
    Chicago
    I'm using win98SE on a laptop P133....I know I know, wimpy wimpy wimpy.....but it only cost me $10 and it runs a gps and winamp.
    Anyways whenever I turn off the car, it just kills the power to the mobo without going through the shutdown process and everything is just fine after several hundred ungraceful shutdowns.
    So, whats the point using a shutdown controller, power sequencer, etc? Just use a dc2dc psu and thats it.
    I'd eventually like to upgrade to win2k, but do I then have to worry about purchasing additional circuitry just to shutdown the os gracefully?
    PS. I'm not sure if this is the right place for this thread but I thought you guys would know the answer.
    Raw Wave
    Jun 2003
    Because you can get lost clusters or cross-linked files if you dont shutdown properly. Even an application crashing can cause file damage.
    I guess you just been lucky so far...one day you may find your file is corrupted.
    Keep trying
    Nov 2003
    Isn't there any way to run all drives in read-only mode? That would make the whole shutdown process pointless.
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    So long as you aren't writing data when the system is shut down you're probably not going to have a problem. Even if the windows swap file is writing, it will just get cleared out and replaced on boot. I'd just run a scandisk once a month. If you haven't had problems by now, you probably aren't going to get them. What errors you do get will be minor, and even bad problems can be solved by a reformat/reinstall.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Jun 2002
    TN
    [QUOTE=cyjad]
    QUOTE]
    Pretty simple here. Most of us are using some sort of method to speed up the boot process. Hibernate, or Suspend-To-Ram. Not only does this narrow the boot time to 15 seconds or less. It also give you the feature to resume exactly where you left off.
    Quincy
    Low Bitrate GScherler's Avatar
    Nov 2003
    Seattle, WA. USA
    [QUOTE=qjones]
    Quote Originally Posted by cyjad
    QUOTE]
    Quincy
    I have never used Hibernate, Suspend to Ram, etc and am looking at the Opus ATX Workstation or the Power Supply as an answer to the shutdown. How does that work. If it's in hibernate and then shuts down does it not need to boot up? I know I'm missing something but not sure what??? Can you lead me to the answer...?
    Thanks much,
    Gary
    ShuttleX SN41G2, AMD 3200+ Barton, PC2700-512, 200 gig Maxtor HD, Opus SFX-1215, 108Mbps WIFI, DVD+/-R+/-RW 4x40x24x40, 7" Lilliput Touch Screen, BU-303 GPS. GScherler@REMOVEcomcast.net
    My Homepage
    Variable Bitrate telekineticfool's Avatar
    Mar 2003
    AZ
    Sure Gary. When I shut my car off, my opus senses that (no more 12V on the ignition lead) and signals the motherboard to shut down (just like you hit the button on the case). It give the computer a few seconds to shut down (or, in my case, go into hibernate mode), and then cuts power. Then, when I boot up, it boots up just like it does when normally coming out of hibernate...ie...right where you left off...middle of the song and everything.
    MP3 MR2 (click here for details)
    Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
    Software: Windows 2000, Media Engine 2.0
    Nov 2003
    Seattle, WA. USA
    Thanks telekineticfool,
    I did not realize that. I will have to try that on my home puter as well. I assumed that windows had to reboot from the begining to get windows up and running first and then go to the last placed you were at. Didn't realize that it would save all that time booting up. Learn something new everyday!
    Thanks,
    Gary
    My Homepage
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Quote Originally Posted by GScherler
    Thanks much,
    Gary
    Well, there are two different modes. Sleep mode will suspend whatever you're doing to the memory, but then everything needs to be reloaded from scratch if you lose power. Hibernate actually saves your status to the hard drive so that boots happen faster. Either way, it's probably not a very viable solution for what you have, because 98 absolutely sucks for either one. Reliable sleep and hibernate recovery didn't really start coming onto the scene until XP. More often than not you will find yourself having to hard power it down and boot from scratch anyhow. I have been doing the hard shutdown method just as you have for almost three years now on a 98 system, and the biggest issue I had was one of the mp3s got gimped. Oooohhh... big problem! Wait... *copy from network*. What problem?
    Anyhow, I wouldn't recommend 2000 for your machine either. It will really slow it down, and will take even more of your limited drive space. Yes, it's more stable than 98, but that's because it's designed to run with specific hardware. If you have a PII laptop, chances are your hardware won't work very reliably under 2000, and even if it did, you're looking at serious stupid long boot times. There is also the increased risk of filesystem damage due to a hard power down.
    Trust me, unless you're willing to spring for a newer rig, or build your own more current-day machine, you should stick with 98. It's resilient, and won't require you to upgrade your memory.
    My first ever carmp3 system was an old Compaq 1060 laptop. It was an early PII, and had a crappy little 1.2gb hard drive. I used mp3s on CDs for that thing, and used earbuds for sound, because my car didn't have a stereo, or even a harness to connect to one. (I was a po-folk back then).
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Nov 2003
    Seattle, WA. USA
    Quote Originally Posted by deadweasel
    deadweasel ,
    Thanx for the reply but I'm confused as I do have a newer puter. Check the signature. The signature is maxed out with what I have listed and do not have room to show that I am running Win XP Corporate version. I have just never used hibernate or anything beside shut down. For that matter, I usually leave my home puter up and running for days on end unless I install a new program or hardware.
    Opps, just went back to the begining of the thread and realized what happened.
    Have a good weekend,
    Gary
    My Homepage
  1. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 10:30 AM
  2. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  3. Help wiring shutdown controller
    By sweetrobot2k in forum Power Supplies
    Last Post: 11-18-2003, 04:09 AM
  4. Cold shutdown controller!
    By phil.45 in forum Power Supplies
    Last Post: 01-13-2003, 10:46 AM
  5. Need help hooking up shutdown controller
    By MAJALO1 in forum Power Supplies
    Last Post: 10-08-2002, 02:27 AM
