Results 1 to 7 of 7
Thread: MPEGBOX Shutdown Controller
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    How does the controler turn the power on to a power inverter? mine is a coleman and it just has a red power switch, i have read the diagram and I under stand how it works for just the DC-DC power supply but not for the switch on the inverter which is what I need it to do.
    Maximum Bitrate SiGmA_X's Avatar
    Jul 2003
    Portland, OR, USA
    Well, I'm guessing you just wire it in serise with your inverter.. So it would be, Battery -> Controler -> Inverter and you would always leave the inverter on. Unless I am way off
    1993 BMW 325is - 15.2sec
    Nov 2003
    NC
    I need it to push the power on the motherboard then after a X number of seconds I need it to kill power to the inverter so that it doesn't drain my battery and make noise.
    Nov 2003
    NC
    I do not fully understand how the controller works.. Could somebody explain it please?
    Maybe the controller does do what I need it to do
    Maximum Bitrate none's Avatar
    Sep 2003
    Quote Originally Posted by owenjh
    This is exactly what it does. Just wire the inverter's 12v positive INPUT directly to the shutdown controller's VOUT terminal.
    Nov 2003
    NC
    Thankyou - I was also wanting an option so that I wouldn't have to turn on the carputer every time so I could use the inverter switch for that - Thanks!
    Newbie Cinco5's Avatar
    Dec 2003
    Detroit, MI
    Where can one of these be bought?
    "If the mirror aint shakin, you've been taken"
  1. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 10:30 AM
  2. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  3. why use a shutdown controller???
    By cyjad in forum Newbie
    Last Post: 12-04-2003, 05:49 AM
  4. Mpegbox Shutdown Controller
    By zootjeff in forum Power Supplies
    Last Post: 09-23-2003, 11:06 PM
  5. MPEGBOX shutdown controller
    Last Post: 12-29-2001, 02:29 PM
