I don't mean to be rude or anything, but good luck. It's kind of tough to make a good system out of that.
ok this is what i got a 133mhz Packard Bell with 1.6GB harddrive and my computer already has the TV and FM input card (it came with my computer). My car is a 93 Lumina Euro. I just want a MP3 player and i want my computer to control everything (speakers and so on) Any help will be appreciated.
Hah! My first system as a P133 and ran beautifully. Older computers handle hot/cold weather better than newer systems.
DMN, you should run MSDOS or DRDOS with MPXPlay. You might be interested in my site as it deals with building a system with a P133. You'll definitely need a larger hard drive, though, but that'll only be an extra $60.
My P120, does moving map and mp3s simultaneously just fine.
I don't know how good your sound card will...well...sound. Other than that, look at some of the other topics here about amps and speakers etc.
thanks man i will look over your site in more detail when i have timeOriginally Posted by Gutter
P.S. I am a unemployed teenager i have no money, i just really want to try this
Originally Posted by D M N
what would everyone suggest as a display for a system such as this?
I had a 133 Packard bell
first off, asses the damage, if you have the sound card/ modem combo toss it 1. its a ***** to get drivers for and 2. sound quality is lacking, buy a newer card
Next you need a new hard drive, since the computer has a bios limitation you have 2 choices, buy a PCI IDE card or use software to override the BIOS only problem is the Software route can be considerably slower than the dedicated IDE card
Next you probably have the built in S3 trio video card as far as i know there was no TV out put so go pick up a used ATI or nVidia card if you truly want the cheap way out
Finally you'll need at least 32 MB of ram and not a Megabyte more than 64! (they had crappy northbridge chips that slowed down considerably when more than 64Mb were installed) and i think all of the P1 systems put out by PB were EDO ram so good luck trying to find some cheap ram!
I think thats about it if you need any more info contact me!
P.S. if you ever see a computer in the trash take it i found a system in the snow 2 days ago that is twice as fast as what you have now![]()
Thanks man i will keep that inmindOriginally Posted by Hcomplyr
Platiunum 55?![]()
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
nope Platinum 40Originally Posted by Custommx3
