Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: processor crushed anyone?
  1. #11
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    Quote Originally Posted by at_b
    robiewp: what processor do you have? i think i remeber seeing your config somewhere and i m pretty sure that you did not have an epia, but i m not sure.
    Car comp version 1 had a regular ATX board with /AMD XP at 1400mhz
    Car comp version 2 has a via m9000
    My car goes from version 1 to version 2 and then back and forth depending on what I'm working on (if car comp version 2 is undergoing changes, car comp version one subs in)
    I drive it like a jeep all of the time.
    car computer rev 5: 8" lilliput and usual suspects
  2. #12
    Dec 2003
    I would say you're pretty safe. Even if your heatsink weighed 1kg (which I doubt it does), in order to get 15kg of force pushing down on your processor, your car would have to accelerate vertically at 14G's (or 137.2 m/sec^2). I don't think the worst pothole in the world would put your car through that.
  3. #13
    Raw Wave
    Jun 2003
    And 14g is more than enough to get you unconsious. I would like to see a car subjected to 14g though
    Ill say your motherboard will get damaged if the weight of the heatsink is allowed to flex it too much.
  4. #14
    May 2002
    see the movies "taxi {1-3}"
    I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
    NavSys, the ultimate navigation app
    http://www.navsys.org/
  5. #15
    Raw Wave
    Jun 2003
  6. #16
    Dec 2003
    Massachusetts, US
    vibration...
  7. #17
    Raw Wave
    Jun 2003
    Got to be a heavy vibratons
  8. #18
    May 2002
    Quote Originally Posted by Ricky327
    as we've all learned in the physics class, vibration effects are carried around matter by particles called vibratons
  9. #19
    Dec 2003
    Massachusetts, US
    what's a half mm of movement at, say, 50 times a seccond? descent acceleration required. Also, keep in mind that near 5kg of pressure is already applied by the clips, making the tolerances only for an additional 10.
    I don't think it's a problem, as i indicated earlier, but I think that in the right (wrong) setup there could be reason for concern.
