Results 1 to 10 of 19
Thread: processor crushed anyone?
    Jan 2004
    Question processor crushed anyone?
    I m courious if anyone had their processor crushed by the weight of the cooler if they hit a pothole or something.
    i think would be something that would happen mostly to amd processors, and i m worried by this since i chose to use a duron proc for my carputer(and the roads are full of holes here...prolly most that any of you can imagine being in a city )
    May 2002
    well, considering the processor is already crushed by the spring action of the attachement of the cooler, I guess it can't really be worse (I did destroy a motherboard once because of the slipping scredriver phenomenon)
    I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
    NavSys, the ultimate navigation app
    http://www.navsys.org/
    Low Bitrate StratusPh34r's Avatar
    Nov 2003
    Atlanta, GA
    I think you'd have a greater chance of the CPU clips breaking due to the weight of the cooler, then falling off, than having a CPU crushed.
    Jan 2004
    well...i posted this thinking that the cpu die is made to take only 15kg of push force as according to amd s tech docs...if i remeber correctly. There are guys that pushed this to 30kg...but i don t think more will be good
    Thinking on it...i guess i m safe if i don t put a heavy cooler on it,right?
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Quote Originally Posted by at_b
    Umm, dude? The proc won't get crushed if you hit a pothole. There would have to be available movement between the heat sink and proc, and with almost all current day processors (PIII/Athlon and on), there is none. Hitting a pothole will not cause the core to get crushed by the heatsink. If you look at the processor, you should notice four small black pads on the corners of the chip mounting board itself. Those pads prevent just what you describe from happening when mounting the heatsink if the first place. Consider them a sort of shock absorber, as well as a shim to prevent the sink from moving any lower than it needs to in order to make contact with the core.
    Also, the problem can be further avoided if you mount your case so that the heatsink is standing out horizontally instead of the normally vertical in a low profile case.
    Hope I could help!
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Jan 2004
    well...hope so , because there are foc loads of potholes around here.
    And i ve seen quite a few crushed amds because of too tight clips.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Once this huge CPU fell from the sky. I mean really huge!!! It crushed my friend standing next to me. Thank god it didn't crush me though...
    O.K. it was a lame joke but it was my first thought after reading the subject.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    If you want to avoid your CPU being crushed when your heatsink rocks back and forth, there's always those Thermaltake CPU shimmies that sit around the die.. they're not expensive either, could always give them a shot.
    I have one on my Athlon XP that i bring to Lans as a precaution..
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    I drive a jeep and I treat it like one. No problems here.
    shocks, CV joints, radiators, water pumps, tires, drive shafts... but no crushed CPUs
    car computer rev 5: 8" lilliput and usual suspects
    Jan 2004
    Quote Originally Posted by starfox
    yup...i was looking for one of those...nobody had them on stock
    thanks for letting me know thermaltake makes them, i ll look tomorrow, that should be good
    robiewp: what processor do you have? i think i remeber seeing your config somewhere and i m pretty sure that you did not have an epia, but i m not sure.
