Results 1 to 10 of 10
Thread: Mounting the LCD inside the dash?
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    This is what I was thinking of doing... I am going to make a mold into plaster of my existing dash piece (which is only about a 1'x1') and then shaping it into the dimensions on my LCD screen. Then just pouring the fiberglass into the mold and then I have my dash piece. But how do I stick the screen to the dash piece? Do y'all just use glue?
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    whatever floats your boat. I used brackets/pressure fittings
    car computer rev 5: 8" lilliput and usual suspects
    Low Bitrate killerfishes's Avatar
    Dec 2003
    im going to bondo-glass the front of the screen into the stock surround. bondo-glass is vary strong and should hold it fine.
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by killerfishes
    So you're going to place the screen in the middle of the current dash piece and then just pour bondo-glass to fill on the gaps between the screen and the dash piece?
    Dec 2003
    you can not "pour" bondo-glass but yes. the stock radio opening is just a hire to small for the 7" screen case, i will open it up but leave some overlap and use the bondo glass to fill inthe crack sand it down and paint it black.
    this is a good how to on the incorperation of stuff.
    http://www.efini.net/dash01.htm
    it still would not hurt to epoxy any place you can first as it will hold stronger than the bondo-glass
    audigy2 NX == done
    pimp rating == 48%
    Dec 2003
    Edmond, Oklahoma
    Do Xenarc and Lilliput screens come with a case like ::THIS::? This is really important to mounting it into my dash.
    Oct 2003
    The Lilliputs do not as far as I am concerned I have never seen them come w/ them nor have I seen them advertised. However I can't speak for Xenarc, my assumption though is no!!
    New CarPC on the way again I think. I miss my old one!!!
    Low Bitrate cotwild's Avatar
    Dec 2003
    Switzerland
    Quote Originally Posted by XxAndyxX
    hey.. where did you get this picture?
    are there any cases for the lilliput screen?
    STATUS: planing / building
    Car: 85' Audi Urquattro
    System: VIA EPIA M10000?, GPS, WLAN, DLink Radio
    Display: 7" Lilliput Touchscreen
    Power: 300W DC/AC Inverter, OPUS?
    Sound: 7.1 Dolby Digital with Audigy2 NX
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by cotwild
    I got the picture off www.digitalww.com it comes with one of his 7" LCD's but it isn't touchscreen. And I don't know if there is any cases for the lilliput that's what I was trying to find out.
    Jan 2004
    Solon, Iowa
    The name of the images is a headrest shroud. So you might look for empty shrouds.
    Here's some without prices: http://www.millertech.com/headrest-lcds.htm
    I'm a newbie - so not sure if these would work. http://www.carmobilevideo.com/category/1.lcdmonitors/
    Here are more monitors - but not shroud only: http://www.qualitymobilevideo.com/6-8headrests.html
    Hope this helped.
    Tom
  1. cover over lcd mount in dash?
    By Mp3 V in forum General Hardware Discussion
    Last Post: 05-07-2002, 07:32 PM
  2. in dash 6.4" LCD $350!!!
    By moahdib in forum LCD/Display
    Last Post: 12-14-2001, 02:00 PM
  3. Suggested LCD to fit in the dash of a 98 civic?
    By zovirl in forum LCD/Display
    Last Post: 08-13-2001, 11:18 PM
  4. Anyone want a Clarion 5.6" In Dash LCD?
    By gguy in forum LCD/Display
    Last Post: 05-30-2001, 11:29 PM
  5. Mounting LCD to Dash - Won't Stick!
    By DaBretty in forum General Hardware Discussion
    Last Post: 07-02-2000, 01:55 AM
