Mase5-
All of your questions could be answered via the search function. I know it is difficult, and getting a direct response seems much better for you get that one-on-one advice; I still recomend the search function. I am still considered "new" as well, but ultimately in what I found via my "search" was not only the answer to my questions (sometimes), but a bunch of OTHER information which I didn't even consider which made all the difference in my purchase / install. So, besides the standard "GO SEARCH" statement many people get, there is useful information there. More than you expect.
Anyways.. To your questions.
1)Of course it is possible. Otherwise they wouldn't make them!is it possible to get these small computers already made up or do i need to build one myselfRather, it all comes down to YOU. What functionality are you wanting? What type of install are you looking for with the CPU/LCD? If you plan on all kinds of different modules inside the box, then most likely the small prefabbed stuff wont be for you. Why? Because the lack of integration. The Casetronic C134 is an awesome little box. Yet, it doesn't offer any option to expand (outside of USB/COM connection). So if you find the onboard video lacking, you are out of luck. Determine your goals and needs, then find the right equipment for that job. How to find the right equipment? Search. Use this website, or use google.com. Search for "mini-itx" or what you need.
2) [quote]if i was to use a program like MediaCar, how do i get the radio thing to work through my computer/laptop [quote] From what I have read, there are a few options. Many people have purchased the D-Link (which is now discontinued) FM radio adapter. Other people just use the MediaCars external application option to open up some app to do the job. With that in mind, check out XM Radio for the PC. Not sure if it would be available for you in the UK though. But read it anyways. It will give you ideas.
3)This question lacks an answer for the simple fact of lack of information. Many people either use the AUX input from the back of the head unit, or use an AMP and FM card and throw the head unit out all together. Give some more details.is how do i get all this to play through my current sony headunit
LinkBack URL
About LinkBacks
