Results 1 to 10 of 15
Thread: reset-on-cranking-
    Jan 2004
    reset-on-cranking-
    what the hell is reset-on-cranking i am lost
    Constant Bitrate ncamara's Avatar
    Dec 2003
    Hampton, VA
    Quote Originally Posted by Evo Designs
    When your crank your engine to start, the computer resets itself and has to restart. Kind of like when you have a power outage for a second, your home computer reboots. Some power supplies allow the computer to run the 2-3 seconds it takes to start up the vehicle.
    Jan 2004
    i see thanks
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Part of that statement is true but I don't think you explained it fully.
    When you start your car you get a voltage drop. If you car has a proper working charging system then your voltage should not drop below 10.5V. This is a voltage level that a lot of inverters use as a cutoff point. Obviously your computer gets no power when the inverter input voltage drops that low and causes it to turn off which will make the computer turn off. So, this is where the reset on cranking term comes in.
    Just an FYI. I've used invereters for all my computer setups in my cars and have never had issues with the computer rebooting.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Dec 2003
    Hampton, VA
    Quote Originally Posted by Defiler
    Some cars actually disable all accessory power while the engine is cranking. The only thing being powered are the required items to get the vehicle running, ie. starter, ignition electrical system, etc.
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by ncamara
    Ahh very true statement. This is why you should, if you want to, wire the inverter directly to the battery to avoid the problem.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Jan 2004
    Hnrm...I have an Unorthodox underdrive pulley so my alternator tends to charge at lower voltage than normal, eventually resulting in my voltage dropping to around 9 when cranking.
    My understanding is that the inverters automatically shut down once they get below a certain voltage...what would happen if that was disabled (if it could be disabled at all)? Would the inverter only put out fewer volts or would it cause some other trouble?
    Jan 2004
    NYC
    Does this happen with the 150w opus DC-DC unit($190.00, it think)
    Why would someone pay 190 when they can get a cheap inverter and it will do the same!
    whats the difference
    thanks
    Maximum Bitrate none's Avatar
    Sep 2003
    The Opus supplies (and Sproggys for that matter) do not have this problem.
    Newbie Mazda6PC's Avatar
    Jan 2004
    Germantown Maryland
    Opus is The ****!
    only problem is the size
    http://www.opussolutions.com/150watt.html
    MVC www.mobiletvsystems.com/
    Check out the shop if your in the Maryland DC VA Area
    2004 Mazda 6s 3.0L
    Epia Via M-1000 512MB
    Opus 150W
    Samsung 80Gb ATA133 7200RPM
    New XenarcTSV
  1. pw70 + itps = no restart on cranking?
    By siueclipse in forum Power Supplies
    Last Post: 01-05-2004, 08:08 PM
  2. Need urgent HELP on POWER prob
    By BOND007BE in forum General Hardware Discussion
    Last Post: 12-15-2003, 12:47 PM
  3. KEYPOWER DCDC restarting pc when cranking
    By Mp3Goose_Your King in forum Power Supplies
    Last Post: 06-09-2003, 01:24 AM
  4. solution to cranking power probs?
    By Jamez_Warner in forum Power Supplies
    Last Post: 05-23-2003, 02:25 PM
  5. Suggestions on buttons (power, reset)?
    By jpainter99 in forum General Hardware Discussion
    Last Post: 09-14-2002, 11:07 AM
