Originally Posted by camsgs3
With a 2 channel amp you can still run those speakers (front and rear)
if you run them in the following manner.
front speakers in series to each other
rear speakers in series to each other
front and back sets in parallel
this would give you 4 ohm total. but the front will be much louder than the rear.
if the front speakers are small this may not work at all.(may end up being too much power to them depending on the amp you get)
before setting something like this up, its important to find out the wattage rating of the speakers.
LinkBack URL
About LinkBacks
but what i would say is this: 2 things: when you pull the HU (as i assume you have/can) you should find some sort of a wiring pinout for the back of it (on my audi's it is just a little sticker with a pin diagram). Look at that and make SURE its not just a switched 12V. if it isnt, you may want to consider relocating the HU to some other (obscure) location and leaving the BUS (sic?) which apparently turns on the AMP plugged in but tapping the line-inputs to the amp and using them for your computer
