Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: People with NO HeadUnit, Recommand AMP!!
    Jan 2004
    NYC
    People with NO HeadUnit, Recommended AMP!!
    This is what i plan on doing, no HU, carputer goes right to AMP - My stock AMP has no RCA plugs and found out my stock AMP wont work without the stock HU,
    So basically I have to ditch the stock AMP and HU
    I now nothing about how all this audio/AMPs get hooked up
    In gonna get it professional installed,but i dont know what to look for on the AMP,
    i think my car is a 4.1(2 fronts,2rears,sub) so the AMP i get, should have 5 RCA "inputs"??
    what AMPs are you guys using without the HU??
    Dont want to spend more then $100 - 150(if possible)
    Now let me get this straight - once my AMP is hooked up with the current stock speakers i just plug my lineout on PC to the rca inputs on the AMP, & I should have sound???
    I just want to get an idea before I go to the install shops, alot of then here(NYC) BS ya alot
    thanks
    Jan 2004
    Potomac MD
    your going to have trouble finding an amp at that price.
    you dont NEED a 5 channel amp (they cost more) you can live with a 4 channel amp... but it has to be a good one, or 2 2 channel amps..
    if you use a 2 channel amp for the 4 speakers inside, and a 2 channel amp (bridged to 1 channel) this will give you the most cost effective solution.
    or if your really trying to keep it under 100-150.. you may want to keep your head unit and stock amp.. and use a rf modulator or a aux or cd input converter for your stock head unit.
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    If all four speakers (all 4 corners) are 4 ohm, you can get away with a 2 channel amp as long as it' 2 ohm stable.
    Rich
    Jan 2004
    NYC
    Quote Originally Posted by srcstc
    Rich
    (front) have 2 ohm impedance values. Rears are 4 ohm and the sub is a 2 ohm
    Can a 2 channel AMP be good with this?
    Jan 2004
    NYC
    Quote Originally Posted by Rami
    Na that would be no good, the whole purpose of this project is for me not to use a HU
    Dec 2003
    New Jersey
    Quote Originally Posted by camsgs3
    No that's not gonna fly. Are you sure the fronts are 2 and the rears are 4? What kinda car do you have?
    Rich
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    what makes you think you cant use your stock amp - as long as it has inputs behind the dash you can convert each RCA into a +/- speaker wire, and if you can grab a switched 12V you can turn your amp on without the HU...maybe an idea if you REALLY want to save time/moeny.
    what kinda car do you have? my audi's BOSE amp can work without a HU....just takes some tweaking....
    Constant Bitrate Adam432823's Avatar
    Nov 2003
    S.F. Bay Area
    Face it... you're going to need to spend more than 150 bucks. You'd need at least a 4 channel amp and then a 2 channel in bridged mono. Not to mention that you'd need either a build in x-over for the sub or a seperate one. Since you're speakers are wierd impedances you're going to have a hard time finding 2 ohm stable amps for that cheap a price range also. Plus, using stock speakers with upgraded amps usually isn't a good idea since you could potentially fry your speakers. All in all... you're in over 150 bucks.
    Why do you want to go through the trouble of installing a versital sound system, that you apparently have in mind, only to short yourself in the department that actually makes the sound?
    Jan 2004
    NYC
    i have a 2000 Lexus GS300 with stock Pioneer System
    Quote Originally Posted by jusatry
    i know cause many people who are VERY familiar with lexus audio systems and who actually tried different setups said it cant be done , Here is one response i got :
    "He said the car's AV stuff is very very integrated with the car, He hinted that the amp might be controlled by a "bus" of some sort, and turn on digitally, instead of a simple 12v switched turn-on. i'd say ditch it. The factory speaker wiring should all be at that amp location, and those should be fine to tap into with your 5 channel amp"
    see when i first came onto this site, i thought i could just use my stock speakers and AMP w/no HU, when it comes to car audio systems i know very very little
    i guess my best bet is to just take it into a professional install shop and make them do it. the PC part i have no prob. doing(setting up,running wire,making custom fabircation for indash LCD screen,etc..)
    just trying to get this audio figured out is a pain
    Quote Originally Posted by Adam432823
    never said i wanted/had in mind a "versital sound system"
    Im no biggie on sound , my stock speakers and sub are fine to me
    The reason i didnt want to go over $150 is because i rather put the money into other things for the PC,GPS Software....like i said sound is not that important for me cause i think my stock speakers sound fine(if they didnt sound good then id be in a different situation)
    thanks guys for all your info/ideas
    Jan 2004
    NYC
    rami,srcstc,jusatry & adam
    Here is a pic of the audio wiring schematics for my GS
    You guys prob. understand this better then me
    thanks again
  1. Stereo headunit or computer
    By mr_anderson in forum Newbie
    Last Post: 01-16-2004, 10:21 AM
  2. What`s your favorite headunit....Aux in
    By PORTUGAL in forum General MP3Car Discussion
    Last Post: 11-22-2003, 10:30 AM
  3. Anyone using the headunit as a am/fm tuner into carputer?
    By -al- in forum General Hardware Discussion
    Last Post: 10-27-2003, 07:52 PM
  4. Equalizer w/ amp instead of headunit - HELP
    By Ivar in forum General Hardware Discussion
    Last Post: 05-03-2002, 08:21 AM
  5. how to feed audio to headunit and shut PC off
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-03-2000, 06:08 AM
