Results 1 to 3 of 3
Thread: Need Help With Power
    Feb 2004
    I have a small Cappucino PC, that uses a brick power supply. The brick AC adapter has the following specs:
    AC Input 100~240V ~ 1.8A, 50-60Hz
    DC Output 18~24V - 3.2A Max. or 60W Max.
    Typical output 18V
    Does anyone know of any solutions that will replace the brick and allow me to use the auto power off feature of other DC boards?
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    There is a laptop adapter that IIRC Radio Shack sells which can output 18V. Then, for the shutdown controller, use the ITPS
    Welcome to the forums, btw
    Co-Developer of A.I.M.E.E
    Newbie Mazda6PC's Avatar
    Jan 2004
    Germantown Maryland
    The cost is $200 but well worth it!
    Check out the shop if your in the Maryland DC VA Area
    2004 Mazda 6s 3.0L
    Epia Via M-1000 512MB
    Opus 150W
    Samsung 80Gb ATA133 7200RPM
    New XenarcTSV
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  3. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
  4. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
