Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Need major help
  1. #11
    Oct 2003
    pretty good price... I guess it would do, I would probably only buy the bare bones of it and buy my own memory and hard drive, you can find the memory and hard drive much cheaper than what they want to sell it for.
    P.S. The only other problem I see is the lack of an OPUS, I would rather have the OPUS than that, but for what you want the system for 60W might just do the trick
    New CarPC on the way again I think. I miss my old one!!!
  2. #12
    Feb 2004
    well i have to run a usb port to my pcm to run my engine management and i also want to but in a small sound system (2 subs and an amp) .
    how about your set up do you like what your running now ? would it be a good set up for me ?
  3. #13
    Feb 2004
    whats the OPUS and what 60W (watts?)
  4. #14
    Oct 2003
    I love my setup, granted it has changed quite a bit from my signature. I need to update my webpage, but I built a customer Plexiglass case, and I'm running my epia board, lilliput. I have upgraded the hard drive because WD hdds have fluid dynamic bearings (some of them do) and that tends to be a bear in the winter. I am a little short on cash right now but I plan on getting my OBDII kit and GPS in about a month.
    As for power I purchased the PW-120 and ITPS from audioforge on ebay.... works great. I think I'm going to update my webpage tonight when I get home and do some posts of my system soon,, been a while since I've updates it.
  5. #15
    Oct 2003
    The OPUS is a power supply, do a on it, there is a ton of stuff on the OPUS all of the forums, the best DC-DC power supply for your car, it survives cranks and it has a shutdown controller and power regulator built in. Its a little spendy but worth every penny... actually MP3car.com is doing a group buy, get in on it. The thread is under Classifieds section.
    The 60W is 60Watts... kind of small, but if your not going to run a lot of things it will work fine... but I think that you will still need a regulator (ITPS) and a shutdown controller for the morex one, but don't quote me somebody will probably correct me on this one.!!
  6. #16
    Feb 2004
    i wanting to install it because i need an onboard system to run my engine management system. i have a 93 rx7 and i put a 2002 corvette engine in it. I think im gonna just borrow a buddys laptop till i can figure some of this out .
    I dont know a lot and id rather take apart an engine them open up the inside of my computer (or try to build one).
    Do you use your computer for watching dvds and is all i need is a sound card for powering a small system? I think ill just wait till you update your web page and ill try to flow the same thing. What was your purpose in going to a carputer?
