i'd get an epia just becuase its compact and takes up less power. The M10k has more then enough horse power to play dvd's. If you get an athlon get an older one under a 1ghz. I wouldn't put anything higher because they produce way too much heat and in a car setup that is very bad
LinkBack URL
About LinkBacks
) and your system is able to draw 600 wats from your battery for 4 hours
