Welcome to the forums!I hope you enjoy your time here! There is a LOT of information here, the search tool will help you a lot!
I can try to answer some parts of your questions
- Power: Probably the best power supply is the Opus - search here for Opus!
- Wiring: Use the standard places the factory wiring goes - pillars, under carpet etc
- Upholstery: Most stuff in newer cars is either clipped or screwed in. If needbe, go to your local dealer and ask the best way to get x bit of trim off.
- Line noise: Try to keep all your audio cables away from power cables. Also, try to ground your audio equipment to the same point. Use reasonable quality cables - especially for grounding, which is just as important as providing +ve voltage! Also search here for "ground loop".
- Basic acoustics: Go to your local car audio specialists, and ask them specific questions about your car. They should be able to tell you which combinations of equipment will sound good together.
Garry
LinkBack URL
About LinkBacks
