Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: A few newbie questions ( heat issues etc.. )
  1. #11
    Dec 2003
    South West, FL
    Quote Originally Posted by sfay93
    I would keep the factory head unit and the factory amps if you are worried about sound quality. Then use the piece I mentioned in the above post to interface with it. I have never had or heard of anyone having any good luck interfacing directly with the factory amps.
    When you are ready to add your sub, just use one of these tapped into your rear speakers to get signal to your amp for the sub:
    http://www.crutchfield.com/S-RcN1tcZ...i=101PL2&g=721
    This would be by far your easiest solution in my opinion.
    Thank you for the great replies to this thread , this has helped me out immensly in trying to finish up the plans for the audio .. I am going to be looking into getting those pieces you suggested.
    Just to make sure I understand.. what i need to do is :
    use http://www.crutchfield.com/cgi-bin/...asp?I=142C4FDK5
    to hook into the headunit and into the pc.
    then use http://www.crutchfield.com/S-RcN1tc...&i=101PL2&g=721
    to tap into the rear speakers to attach the sub to the factory amps.
    am I correct?
  2. #12
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    This for hooking into the head unit if you plan on keeping the factory:
    http://www.logjamelectronics.com/piefrdnaux.html
    and the instructions:
    http://www.pie.net/frdn_aux_inst.htm
    and then this for the amp to the subs:
  3. #13
    Dec 2003
    South West, FL
    Thank you again , this is perfect
    Scorpnstail
  4. #14
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    Just be sure to buy a well-ventilated enclosure. That will help during the hot days.
  1. some questions for a newbie
    By mr2 in forum Newbie
    Last Post: 11-19-2003, 04:40 PM
  2. Replies: 6
    Last Post: 10-26-2003, 01:27 PM
  3. Replies: 9
    Last Post: 10-07-2003, 09:19 AM
  4. A few newbie questions?
    By woodpaneling in forum General Hardware Discussion
    Last Post: 08-13-2003, 11:52 AM
  5. Newbie with questions...
    By Felix in forum Software & Software Development
    Last Post: 05-25-2003, 01:57 AM
