Results 1 to 10 of 17
Thread: Odd Question for Mounting the Monitor
    Dec 2003
    South West, FL
    I am hoping there may be someone that can lead me in the right direction with this , I am hoping to mount my monitor on one of those bendable arms you usally see on lamps. Does anyone know where I can find these bendable arms ? I know this is a odd question but after searching for lamps for the past few days I am getting a little worn out on looking at lamp stores and finding a decent arm on a lamp for $98+ . Has anyone seen these on anything else?
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    Go to Home Depot and look around their pipe/wireing section. I belive they may have some sort of pipeing that will do that. If not, I think Home Depot might even have a desk lamp type thing that'll work too! Nice idea though, I hadn't thought of that.
    Good Luck.
    Dec 2003
    South West, FL
    Quote Originally Posted by Cherub211
    Good Luck.
    Hmmm .... bendable piping I will check Lowes / Home depot for that tonight. I am wondering how those bendable arms are made, It may be good to craft one myself if it is not to time intensive.
    thanks
    Scorpnstail
    Constant Bitrate cafn8's Avatar
    Mar 2003
    New Jersey, US
    The type of flexible arm you're referring to is usually referred to as a "goose neck". That term might help you in your search if you were calling it something else.
    I'll agree the Home Despot is a great place to look for just about any build project. I just like to go and browse. You might find something you didn't expect that fits your needs.
    Feb 2004
    Chandler, AZ
    I've also seen some ball joint hoses used in intustrial applications that would work in the same manner but I don't know the name of those. That dosn't help you does it?
    Feb 2003
    One could also take fully interlocked tubing, then put some heavy gauge copper wire inside the tubing to carry the weight of a small monitor. The copper wire would be felxible and the tubing would keep the wire in place.
    I am not sure how this would handle the bumps on a road but it would be a start.
    Feb 2004
    Chandler, AZ
    I'm thinking that copper wire might bounce around in a car wouldn't it? That would make your screen a little hard to see.
    Dec 2003
    South West, FL
    Quote Originally Posted by cafn8
    Actually I was refering to it as just "bendable lamp arm" in my searches as I could not think of the word.
    I can honestly say I have no idea what you are refering to there
    Quote Originally Posted by reldridg3
    Actually this is a very good idea .. I can see going to Lowes or home depot and picking up some flex conduit and also picking up some thick copper wire .. take enough to fill the conduit and that shoudl be enough to hold up to some aggressive driving. Correct me if I am wrong here
    Scorpnstail
    Feb 2004
    Chandler, AZ
    I don't know I'm an electrical engineer, not a mechanical one.
    Dec 2003
    South West, FL
    .. right now I am just hoping for the best , but you may be correct that it would not be able to take the vibrations of the car .. I just remember seeing some pretty thick copper wire that held its shape really well and was thinking you get a bunch of this together it sould work great . not sure what thickness I am refering to though.
  1. flat screen lcd monitor power question
    By DeliriousAmi in forum LCD/Display
    Last Post: 01-03-2004, 08:45 PM
  2. LCD monitor question
    By owenjh in forum LCD/Display
    Last Post: 01-02-2004, 06:08 PM
  3. TFT/LCD monitor question
    By suprchrgXterra in forum LCD/Display
    Last Post: 12-21-2003, 05:05 PM
  4. Odd Switch question
    By TruckinMP3 in forum General Hardware Discussion
    Last Post: 06-05-2003, 10:26 PM
  5. LCD monitor question.
    By Dex4now in forum LCD/Display
    Last Post: 12-07-2002, 06:46 PM
