Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Connecting carputer to stock amplifier of a 2001 Pontiac FireBird TransAm?
  1. #11
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    Quote Originally Posted by WWE-TicK
    So what do I need to do to make the signal from the sound card balanced? Would it be possible to get another amp that has RCA inputs, hook the carputer up to that, and then hook up that amp to the stock amp?
    If you want to go from unbalanced to balanced, the effort is not worth it.
    I would just buy an amp and replace the stock one. The stock audio, however, may need to go then.
    That's what I did in my setup. The stock audio system in my car was very "picky", so I replaced and rewired most of it. My PC is used as a headunit.
    Looking over the schematics diagram, it will be a pain to keep your speakers. It seems that the stock amp has x-over built in. I had to replace my rear speakers for this reason.
  2. #12
    Aug 2006
    Central PA
    Did you ever find a solution?
  1. 2001 Pontiac Firebird TransAm and a DWW-7VGA?
    By WWE-TicK in forum LCD/Display
    Last Post: 02-12-2005, 10:16 AM
  2. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 01:21 PM
