Results 1 to 4 of 4
Thread: Directron Case
    Mar 2004
    Directron Case
    http://www.directron.com/epiam.html
    Will that case work with the EPIA M10000 and a 90w OPUS? I would obviously remove the supplied PSU and use the OPUS, but would there be enough room for it in the case with a Normal size HDD?
    What case would you guys recommend a carpc beginner that is fairly cheap and needs very little custom work??
    Low Bitrate shadowpuck's Avatar
    Mar 2004
    Quote Originally Posted by EzEddie
    I'm fairly new to this hobby myself, but from what I can read this case would work with any mini-itx board. It would give you the option of using standard size drives if that's something you want to do - which helps with the budget...
    I have ordered items from directron in the past and had good luck - fwiw...
    Jul 2003
    Atalnta, GA
    Close, but no.
    I just got my 90w Opus today, and found out the hard way that it does not fit in this case. The opus is about an inch too long (or the case is an inch too short, you decide.) I either have to get a new case, or mount it on the side, which I'm not really excited about.
    Skippy
    Mar 2004
    anybody buy any cases from there that have fit a M10000 + 90w OPUS?
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Looking for a case...
    By gork in forum General Hardware Discussion
    Last Post: 08-05-2003, 02:02 AM
  3. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
  4. Mounting the case
    By TheFly in forum General Hardware Discussion
    Last Post: 05-05-2002, 04:11 PM
  5. Cool looking case for fv24
    By B3AND1P in forum General Hardware Discussion
    Last Post: 04-20-2002, 12:28 PM
