Originally Posted by
telekineticfool
alright, i'm not sure how many of your points have been covered elsewhere, but I'll have a go at it.
First off, if you have the time to research your setup for two months, you have the time to build it correctly...unless you're getting it installed professionally you are onlly going to marginally save time by not assembling it yourself. Most of the major DIY work is done to save money, which, based on the choices you outlined, doesn't seem to be an issue. However, upon more closely reading your posts, what exactly are you buying instead of building? The case itself? It looks like you're planning on assembling from scratch components...
