Originally Posted by
none
If this setup comes with the 60w psu that I think it does, then yes, you can, although I do not know if it will fit inside that tiny case. The ITPS does have problems when the voltage drops, however, like when starting the car, or sometimes even when the car is just not running. You can bypass the regulator on the ITPS to alleviate these problems, but then you are passing along unregulated 12v to your components. From the looks of it, none of your stuff uses 12v, so you might be ok with this.
