Results 1 to 9 of 9
Thread: question about lilliput
    Mar 2004
    if i buy the lilliput and put a PC in the trunk, and wire it up and all what is the best way to get the audio integrated in the sound system?, through the aux input?
    what other accesories will i need to be able to hook up my PC to my car.
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Quote Originally Posted by cnagot5onit
    cnagot5onit,
    Basically you have three ways. 1) Go headless and wire the sound card to an amp, controll volume thru PC 2) Use an FM modulator to connect the PC to you head unit (conects between the antenna lead) 3) If your head unit is capable, you could connect the PC directly to the cd changer slot with one of the adapters you can find referenced here.
    Batman
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    If your head unit has aux input, that is the best method.
    Mar 2004
    so basically the touchscreen does everything a moes does?
    any down sides to touchscreen that you have all notices?
    Apr 2003
    HOT Arizona
    It is hard to drag. Hard to right click. Hard to play games. Hard to hit the X or _ buttons.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    The touchscreen also creates more glare and significantly degrades the brightness of the screen.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Sep 2003
    Newark, Ohio
    I love the touch screen in most cases. However, I do have a wireless mouse and keyboard in the car. Touchscreen is great, but mouse is definately more precise and faster.
    Batman
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    Quote Originally Posted by Batmanatthenewb
    Batman
    not when you are driving.
    [ 5-spd 1996 M A X i M A SE ]
    Sep 2003
    Newark, Ohio
    Quote Originally Posted by nadir_s
    Yea, touchscreen is easier for the majority of everything in Mediacar. But, like most lilliput owners, the bottom right corner has a spot that wont calibrate correctly. So when i'm looking for a name/address/phone number in Outlook, or the little window pops up saying "you are connected to "X" network", the easiest way to get rid of it is to use the mouse and click the "X", yes, while I'm driving.
    Batman
  1. Replies: 5
    Last Post: 02-20-2004, 02:08 PM
  2. Replies: 0
    Last Post: 02-17-2004, 07:10 PM
  3. Lilliput Question
    By patrol in forum LCD/Display
    Last Post: 12-28-2003, 07:15 PM
  4. Lilliput install question
    By Audamn in forum LCD/Display
    Last Post: 12-13-2003, 07:29 PM
  5. Lilliput Cable Question
    By rgardjr in forum LCD/Display
    Last Post: 11-17-2003, 09:49 PM
