Results 1 to 5 of 5
Thread: hibernation possible when triggering inverter
    Mar 2004
    Ontario Canada
    Guys,
    If windows is setup to hibernate upon pressing the power switch, will it still work if you cut power to the inverter?? This is considering that the BIOS is setup to boot up after power loss. Is this type of shut down considered a hard or soft shut down?? Thanks Fern
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Hibernate is a hard shutdown you can kill all power to the computer and it will still resume from hibernate afterwards.
    Quote Originally Posted by syclone477
    Guys,
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Mar 2004
    Ontario Canada
    I cant get my desktop to do that. I have it setup to hibernate when you press power, and I have the BOIS set to boot up on power loss. If I pull the power cord will in windows, then plug it back in, it will not go back into hibernate?? Any Ideas??
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    When Windows goes into Hibernate mode, it copies the entire contents of RAM onto the HD.
    If you just pull the plug, it doesn't have time to do that, so it has nothing stored that it can return to. You need a delay before killing power so it has time to shut down properly.
    An ATX power supply doesn't use a simple on/off power switch. It's a soft button, more of a suggestion to shut off, rather than forcing it.
    Pressing power doesn't actually shut off power to the computer, it sends the signal to Windows to start the power-down sequence. If you don't give it time to finish, you can't restart from hibernate mode.
    Kris
    Mar 2004
    Ontario Canada
    understood, I was unclear about that. Thanks Fern
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  2. Help with inverter
    By Starkan in forum General Hardware Discussion
    Last Post: 07-10-2004, 06:43 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  4. FS:HYPERION Simplicity Series standalone Controller and inverter
    By kickercivic1 in forum Classified Archive
    Last Post: 06-25-2003, 09:01 AM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
