Results 1 to 2 of 2
Thread: Power on/off question
    Mar 2004
    When the switch is turned into acc mode the carputer starts powering on, what if I turn the key off right away? Will it finish turning on and the shutdonw? Same thing for carputer shutting down and I turn the key back on? If the carputer will follow power on/off procedures properly, what kind of a delay are we looking at here?
    Also what is the fastes anyone ever manage to get their carputer to boot up both cold boot and from hibernation.
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    I'll try to answer, even though you're not too happy with me.
    If you're using Opus PS (not sure about other controllers), it will push the power button after a delay. It works well, leaving a PC just enough time to get to the point where OS will shut down when the power button is pressed on MB.
    The quickest I've had was 30 seconds full WinXP boot-up.
  1. Power Question not asked
    By mbkowns in forum General Hardware Discussion
    Last Post: 03-06-2004, 04:38 PM
  2. Power consumption question
    By S4Per in forum Power Supplies
    Last Post: 02-16-2004, 05:08 PM
  3. Question about power and inverters and all that
    By SBmp3 in forum General Hardware Discussion
    Last Post: 04-30-2003, 11:35 PM
  4. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 02:36 AM
  5. Power Supply & TFT LCD question
    By VegaBOND in forum General Hardware Discussion
    Last Post: 03-23-2000, 06:07 PM
