Why not use a FM modulator to connect your mp3 player to your head unit?Originally Posted by st11x
Hi guys,
I've got a portable MP3 player and had been meaning to hook it up to my car. I was going to buy an amplifier unit, but the cost is a little prohibitive for my usage. Also, it's pretty time consuming to do it.
I then thought about getting a set of portable 2.1 PC speakers, something in the likes of the TDK Tremor. Has anyone gone this way? If it runs on AC, I would require a power invertor right?
My MP3 player has optical outputs, so I would like to take advantage of that. But I guess there isn't any portable speakers around that will take optical inputs.
Appreciate thoughts from members of this forum.
thanks
Matthew
I know my PC speakers run off of a 12v DC source, I'm sure most if not all use an external transformer so all you would need is a regulator so that when the car is pumping out 14.5 volts you won't fry it.
But like what was mentioned... an FM modulator would be much easier
Thanks guys,
I was thinking about the modulator, but what swayed me towards the 2.1 PC speakers is the sub-woofer that would make things a little nicer![]()
I'll check out the regulator like you mentioned.
thanks
Matt
My computer subs/speakers have optical in, they are harman/kardon. I thought about putting this sub into my car and running it off of AC. the problem I ran into was noise. Most PC speakers won't be grounded well, at least in my experience. If I were you, I would stick to car audio in your car and get a AUX input into a CD changer port you aren't using or a cord like this: http://www.logjamelectronics.com/piejvcaux.html
-David
