Results 1 to 9 of 9
Thread: Double amp. installation ????
    Mar 2004
    Denmark
    Hey everyone...
    im finally ready to install my car comp. and i have a problem....
    i have 2 amp. in my system one is a 4 channel amp that is connected to the 4 speakers, and to the pc no problem.... the other one is hooked up to a sub. but how do i connect the sub and amp to the rest of the system ???
    hope you understand my question...
    Best Regards
    Kenneth
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    You could probably get away with splitting the audio output into 2 RCA pairs as it is going to be amplified anyway.
    Two of those will do.
    If sound quality isnt great then you'll need to get a pre-amp which will give you two RCA outputs from one input while keeping sound quality as good as the original.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Mar 2004
    Denmark
    Quote Originally Posted by no1knows
    Thank you for your reply, but i am not sure i understand what you say....two of those cables will do, to split the signal or ??? and do i need a 3 amp, to get the correct signal ???
    Kenneth
    Feb 2004
    You could buy two of those cables to split the signal (see pic)
    Or you could simply strip the cable and join on another RCA pair which is basically doing the same thing.
    Or for the best sound quality you'd need a pre amp to keep the signal strong, when you split an audio wire you take someof the signal strength away, but as its being amplified anyway you'll probably be ok splitting it.
    Mar 2004
    Denmark
    Okay thanks a million
    Is this the same way that you have done it in your own car ?
    I will try this tonight and see how i works.....
    Kenneth
    Feb 2004
    I have the laptop running audio to my pioneer head unit through an AUX-in box. The head unit has 3 RCA outputs so i've had no need to split them. Easier for me as i had all my amps connected to the head unit before i started.
    Glad to be of help.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    What kind of sound card do you have?
    Does it have more than one output?
    Depending on your sound card you might have a .1 out (sub out). Me personaly I'm going from my sound card to a Clarion pre amp/eq to my two amps.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Newbie djjazzman's Avatar
    May 2003
    MS
    Does the 4 channel amp have an aux out(pass thru) for connecting other amps?
    Mar 2004
    Denmark
    Quote Originally Posted by djjazzman
    Hey to you all...
    I had a very good frend helping me install the system, "schakenda" and we
    connected the two amps, with the splitter cables, and i works great !!
    thanks for all your replies....
    Best Regards
    Kenneth.
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  3. PC -> Amp and HU - Amp question
    By Nokia6600 in forum Newbie
    Last Post: 03-24-2004, 05:42 AM
  4. Replies: 1
    Last Post: 11-17-2003, 04:21 PM
  5. EPIA M9000 connection to car amp
    By wi77iam in forum General Hardware Discussion
    Last Post: 08-08-2003, 02:37 PM
