Results 1 to 10 of 11
Thread: Lilliput indash non motorized housing
    Sep 2003
    North Virginia
    A while ago i saw a houseing that fit in a empty din and housed a Lilliput monitor
    it wasnt motorized
    anyone know waht im talking about
    and more improtantly do you know where to find it?
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Wow...another opportunity. Well, here is your freebie...
    http://digitalww.com/DWW-7VGA.htm
    check out Armen's site. This is one of the non-motorized setups, but I believe he has others. I didnt wannna take all the fun out of searching for it for ya
    BTW, maybe you are talking about the empty housing, it should be there also, otherwise email him. It may take a while (read...a WHILE) to get a response, but he will email you back, be patient
    2005 Ford Focus ST
    Sep 2003
    North Virginia
    http://digitalww.com/indashhousing.htm
    i found this
    does anyone know if it swivels?
    Dec 2003
    Portland, OR
    Monitor is Adjustable UP/DOWN & RIGHT/LEFT
    -Viewing Angle (L/R:60 deg U/D:25 deg)
    2005 Ford Focus ST
    Sep 2003
    North Virginia
    do you think its worth spending the 500 on the complete item
    or spending the 100 on just the shell and trying to install the screen into it my self?
    Nov 2001
    NYC
    Quote Originally Posted by crash893
    Can you solder? Are you good with electronics? Do you mind throwing away $350 if you mess up? Are you ok with having no warranty if something goes wrong?
    Ask yourself these questions and then you'll know your answer. Honestly, its not that difficult, but you need time and patience to do. But if you don't have time or don't wanna deal with the hassle, let armen do it for you.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    its not to hard to convert it to fit this housing, but the housing doesnt come with any way to secure it in the din slot, which is a shame. I'm still looking in to a way to do this. The $500 deal from digitalww also uses the same housing.
    Steve
    Sep 2003
    North Virginia
    so its not secure in there
    im not well versed in car audio so im not even really sure what it looks like in there
    the reason i want it to go in like that is becuase there have been a rash of car break ins at my area
    and i figured having a screen mounted to the vent woudlnt help my chances
    also it says USB touch screen but all i see are 2 rca 1 vga and 1 serial
    anyone care to explain that to me ( i already emailed the company but havent heard anything back)
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I just finished with, and have installed in my car.
    The good point is: it is cheaper than the complete package, but you do need to know how to solder, and you need some significant skill. You are required to solder some very small connections, and it is easy to screw up.
    Bad points, it doesn't quite fit into a standard DIN slot (but then again, I don't think a computer is really meant to fit into a car, is it?), and it doesn't come with any sort of mounting hardware. The screw holes in the mount are the same as a standard radio bracket, but you really have to be careful on how deep you put those screws (<2mm) or you will block the carriage.
    In my opinion, go with the housing, get youself a decently small soldering iron, some solder wick, and take your time. I had mine done in about 2 days with lots of breaks.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    If you'll decide to do this yourself then order the housing from this link: http://www.digitalww.com/MP3CAR/indashhousing.htm
    I will be offering Lilliput in-dash monitors (converted by me) very soon so email me and we will talk.
    Armen
    armen@digitalww.com
  1. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 07:58 PM
  2. mount LCD w/o housing - lilliput 619
    By cybermob2 in forum LCD/Display
    Last Post: 05-04-2004, 04:14 PM
  3. indash housing and lilliput?
    By LudeAtude in forum General Hardware Discussion
    Last Post: 02-07-2004, 05:31 PM
  4. think this housing would hold the lilliput?
    Last Post: 12-31-2003, 07:55 AM
  5. Replies: 14
    Last Post: 10-14-2003, 09:25 PM
