Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: DOS File Transfer & CPU Control
    Dec 2003
    I'm working on a basic car MP3 player, and right now it is running windows 98. But it's only a p1 133 or something along that line, so I would like to run DOS and MPXPlay because windows takes too long to boot up. Accept I was running Remote Administrator on Windows and used that to transfer and set up stuff without having to take it out of my car. Does anyone know how I can do all this stuff, enable networking and have a remote desktop with DOS?
    Feb 2004
    Michigan
    Quote Originally Posted by Powers
    i can help you with file transfer.. a bat file i wrote:
    net use x: \\raydesktop\Media\Music
    xcopy x:\*.* c:\Music\ /D /Y /S
    net use x: /DELETE
    line 1 maps a network drive to the location where the source folder is. line 2 copies all files that: dont exist in the destionation folder, or if they exist, if the source file has a newer date, copies it. line 3 closes the network resource. i like the date checking because i like to keep my car's music library updated against my desktop's. if i change an ID3 tag or somthing, the change will carry over, and it only copies updated or new files, so i dont waste time copying gigs and gigs of music over when i only want to update a few songs. i dont know much about dos or networking in dos or anything. i'm young, it was before my time i hope i helped.
    ray
    Dec 2003
    Ya, everything worked so well in Windows, but it's just too damn slow. Dos would be nice, but i don't know how to use it.
    So what do I do with that bat? exec it on the computer I'm transfering to?
    Feb 2004
    Michigan
    yeah, save it in notepad as a .bat, and it will execute like an .exe. its written now to be on the computer that is being transfered to, but if you want it on the other one:
    net use x: \\rayscar\Music
    xcopy c:\Music\*.* x:\ /D /Y /S
    net use x: /DELETE
    Dec 2003
    OK, thanks. If you have any ideas of how to enable netbios and file transfer between a DOS and Windows XP machine let me know.
    Also, how does one start up MPXPlay on bootup?
    This DOS is almost all french to me.
    I have a MPXPlay boot disk, but it takes just as long to load, will that work if I copy it to the hard drive?
    Feb 2004
    Michigan
    you can get a faster computer for pretty cheap... http://www.tigerdirect.com/applicati...MBM-M6VLQ-1300
    quite an upgrade for 80 bucks. also try newegg.com if you are interested, they might even be cheaper.
    Feb 2001
    DOS doesn't have built-in networking support. It can be added, though, by installing additional software. This page gives instuctions on how to install the Microsoft Network Client for DOS.
    http://www.wown.com/j_helmig/dosclnt3.htm
    With this Microsoft client, one can map drive letters to Windows networking shares.
    At the bottom of the page, there's a link called "DOS-based Microsoft Network Server". It gives instructions on how to get things set up so one can share files, on the DOS machine, with other Windows-based computers.
    There's a batch file called autoexec.bat, which is automatically run when you boot into DOS. You'd add a command at the end of the batch file, to tell DOS to run MPXPlay.
    Here's a couple of tutorials that cover the basics:
    http://www.users.globalnet.co.uk/~jchap/tvdt.htm
    http://www.homepages.better.net.au/t...STUTORIAL.html
    I'd grab a copy of the most recent version of MPXPlay and start fresh. The version of MPXPlay on the boot disk may or may not be recent, and who knows how it was configured. You'll definitely want to put MPXPlay on the hard drive.
    Since you're running Windows 98 you won't need to install DOS. It's already there. In the root directory on c: drive there's a file called MSDOS.SYS SYS files are normally DOS device drivers, but not this particular file. Open it up in a text editor (Notepad is fine). Near the top you should see a line that says: BootGUI=1 Change it to BootGUI=0 When you reboot, the computer will boot into DOS, instead of loading Windows. If you need to get back into Windows for some reason, just type Win at the command prompt.
    Dec 2003
    Ok, I installed DOS 6.22 fresh, mainly because I only have 740 Mb of hard drive space to work with. I've got it all loading and stuff, I just need to network. Hopefully I can get that all working.
    Thanks for the help guys.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    www.wown.com was invaluable when I was setting up ndis drivers under dos. Unfortunately they appear to have removed their dos section now, but archive.org still has the old version:
    http://web.archive.org/web/200306221...g/dosclien.htm
    Dec 2003
    OK, I got the Dos client on the computer, but there is no TCP/IP, which i need to get on my network. Does anyone know where i can get tcp/ip drivers for an SMC EtherEZ 8416 card?
  1. XP to 98lite file transfer error
    By jakeep in forum Software & Software Development
    Last Post: 04-04-2003, 06:11 AM
  2. win me worth it?
    By schrodos in forum Software & Software Development
    Last Post: 04-27-2002, 08:53 AM
  3. Vote Skinny Boy off the Forum??????
    By radioman193 in forum Mp3car Forum Suggestions/Comments
    Last Post: 09-17-2001, 12:42 PM
  4. Reading CDRWs in Dos
    By redscar in forum Software & Software Development
    Last Post: 08-21-2001, 03:00 AM
  5. Okay, guys, I need some help....
    By dapepster in forum Software & Software Development
    Last Post: 08-20-2001, 03:31 AM
