Results 1 to 3 of 3
Thread: Newbie idiot stupid Volt/Amp question
    Registered User Iceman's Avatar
    Switzerland
    My laptop AC Adapter is 16V -- 4.5A
    If I buy a cigaret lighter type plugin that is:
    15/16/18/19/20Volt, 3,5A (max.)
    Does that mean that the battery will not charge (but the laptop will run fine)?
    Will my car battery drain if the laptop is turned off, but plugged in to the power source (power source is always on, even if the car is not running)?
    Thanks,
    IceMan
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Although the laptop AC adapter will give upto 4.5A, it does necessarily mean the laptop needs that much (although it may well do). The chances are that the laptop will charge but may not run properly, charging does not need that much current, it make just take longer to charge fully. The main issue will be with the LCD screen and back-lite, floppy running, CD running hard-drive running, the processor running there will be enough current for all that.
    there will be battery drain, but it should be negligible
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I have tried this...and probably you will not have enough juice...especially if your car voltage drops a tiny bit. Get something that has the correct volts...and at least that many amps. You will be happier in the long run.
  1. Yet another stupid newbie question (ITPS)
    By Nokia6600 in forum Newbie
    Last Post: 03-19-2004, 04:43 AM
  2. Stupid Newbie Question!
    By robchopper50 in forum MediaCar
    Last Post: 03-06-2004, 05:37 PM
  3. newbie question about LCDs
    By Hagakure in forum LCD/Display
    Last Post: 02-02-2004, 11:37 AM
  4. stupid question
    By Cliff in forum MediaCar
    Last Post: 11-19-2003, 04:10 PM
  5. Is this a stupid question??
    By Raymond in forum Power Supplies
    Last Post: 05-23-2001, 01:01 PM
