well the your computer uses DC so you will be needing a DC-DC power supply, unless you mean an inverter, I use one but most guys on the board will tell you to go with a DC-DC supply which usually costs over $100 as opposed to a $30 Wal-Mart Special.
I'm sure youre aware that the audio jack on the back of your computer is a 3.5mm headphone jack, all you need is an adapter (wire) that has a headphone plug on one end and RCA's on the other (Radio Shack, Fry's, even Wal-Mart, Etc.
If you really want this thing to be useful as a gps and be able to read the words without going lo-res and extra large fonts then you should get a VGA screen, and don't go cheap and hold off on the touch screen, that one component makes the system worth having for me. I used a remote, keyboard, and mouse before, I still use them if needed but the touchscreen makes everything much simpler not to mention safer.
LinkBack URL
About LinkBacks
