Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: where to buy wire to run from battery to inverter?
  1. #31
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    I wouldn't run any large amount of current thru a switch, use a relay and then use a switch to turn the relay on and off...dont forget your FUSE!
  2. #32
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by Pokey
    i agree...but the switch is rated for 30 amps...so it really shouldnt be a problem as long as you aren't pulling more than 30 amps (or 30 amps for an extended period)
    rebuilding carpc... kinda..
  3. #33
    hud
    hud is offline
    Mar 2004
    here's the switch:
    http://www.radioshack.com/search.asp...e=search&SRC=1
    (the first one...item # 275-712)
    so, you're saying typically you don't wire a switch directly in, you instead wire a relay in, and wire the switch to the relay?
  4. #34
    Mar 2004
    Oshawa, Ontario, Canada
    Quote Originally Posted by hud
    Yup, that's what relays do best
  5. #35
    Newbie Camryputer's Avatar
    May 2004
    Michigan
  6. #36
    Mac Car Moderator kandyman676's Avatar
    Maryland
    k, so that i have this straight, cause I am basically going to be doing the same thing:
    it goes on the positive side from battery to fuse #1 to relay to switch to fuse #2 to the load...and then the load (being the computer) gets grounded?
    or is fuse #2 suppose to go between the relay and the switch?
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
  7. #37
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    what is the best gauge to use for the power wire?
  8. #38
    Tampa, Florida
    Wire it like this, i usally run the largest wire i can get. 6 gauge is best. Anything smaller (12,14, gauge) causes a voltage drop over a distance and you will end up with less voltage at your device. Always get negative from the cars frame or body, and try to switch ground, when practical (horn relay is an example, its best to have a long wire at ground potential), not switch hot.
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  3. Replies: 11
    Last Post: 03-09-2004, 09:59 AM
  4. inverter overload?
    By dizzzyduck in forum General Hardware Discussion
    Last Post: 03-27-2000, 12:41 PM
  5. buying an older car....Power questions
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 03-04-2000, 02:07 AM
