Results 1 to 4 of 4
Thread: Embarking on this
    May 2004
    UK
    Embarking on this
    Hello Guys as u can tel i am new to the forums. I have had my eye on them for the past few days and have noticed the quality of the replys and help. I know my computers well lol and my sound well i know a little about it. So i though lets give it a try
    I am about to start my project and thought i might/will lol- need ur help
    I have just a few questions
    1. Is it o.k to run a 300 Watt inverter straight off the cig lighter then just plug the computer into that. If i do this obvoiusly when i turn the key off the computer is gonna shut down
    2. Where is the best place to mount computer For running wires etc from the touch screen.
    Cheers
    Sam
    Newbie NitroNic's Avatar
    May 2004
    Oklahoma, USA
    Eeek... I'm not an expert on this... but I do know that if you have 300 watts...that's pulling about 25 amps on your cig lighter...I would probably not do that; I would run some heavier gauge wire from another power source. And if it's not already fused, I would fuse it. And I'm not sure...but I think on some cars, the cigarette lighter will remain powered even with the ignition switch off.
    For question #2, that would depend on your vehicle. Mine is probably going in the trunk somewhere. But if you have a pickup truck of course that won't work. Another place, if the computer case is small enough, would be under a seat (again, if there's room). Just make sure there's good air circulation.
    Hope this helps
    Nic
    Constant Bitrate Aftaab001's Avatar
    Mar 2004
    Kent, UK
    As nitro said, run a heavier gauge wire from the batt positive terminal, fuse it no more than 30 cm away from the batt terminal and to where your inverter is. Make the ground wire as short as possible because you are bound to have interference problem if not grounded properly (especially with the inverter case).
    AWG recommendation for positive (from batt terminal to say boot approx 16ft) 10 - 12 AWG should be fine. For ground i would make it about 30 cm or less with 10 AWG.
    You should add a relay to the wire as it will be always on for the inverter input.
    Hope this helps..http://www.the12volt.com/info/recwirsz.aspv
    May 2004
    UK
    cheers guys for the help.
    One last question what GPS software would you recommend and where could i *download* a copy from lol-
