Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: I am Extremely new and need your help
    Newbie stillatin6's Avatar
    May 2004
    i am extremely fascinated by carputers and would like one installed in my future car : the scion tC i am wondering where can i put a screen in this dash and any other help or advice can u offer me thanx in advanced...
    the cars interior
    diffrent angle
    farther away
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    If that head unit is double-din, then take that out and put a 7" touchscreen in that gap. Wire up the computer to an amp, and hook into the existing audio harness, and you'll be fine
    You even have a cover to go over the screen when not in use, which should make it less attractive to theives, as they won't know it's there
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Hayling Island, UK
    yeah, like confused said, where the double din is.
    you might beable to moterise the shied(cover) so it opens/closes automaticly, show off to your friends
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    Scion TC is the sedan right? Get the $3g supercharger
    Ok anyway take out that HU and just mold a screen in there and that cover flips down to cover up so that spot just becomes perfect. Stock double din units are trash anyhow (and scion isn't exactly a luxury brand). then Im sure you can moun the carputer in the glovebox.
    Mine needs to be updated.
    May 2004
    thanx to all whom replied
    so far i need to ...
    take out the hu and install a 7 in. lilliput
    so if the lilliput is smaller than the head unit what do i need to do?
    connect the computer to the amp and hook into the radio harness
    will i need additional wires for that?
    maybe motorize the cover so it opens close automatically
    that is a great idea too bad im not a electronic whiz i would need ALOT of help on that lol
    mold the screen
    i will probably do a search on this because i may need bondo and fiber glass am i correct? if i do i dont think i would wanna be the one messing with that because i have never worked with either before..
    can ya help me out some more guys? thanx in advanced
    Hayling Island, UK
    mold the screen so it fits (bondo, fiberglass), the forum for info
    connecting the pc to amp will require aditional wires, if car doesnot have an external amp you might need one of those 2. also might need a pci/external sound card for better quality audio
    moterising the cover will need looking at how it actualy works behind, could be as simpe as a moter pulling the cover back via cogs
    Tom
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Quote Originally Posted by stillatin6
    i will probably do a search on this because i may need bondo and carbon fiber am i correct? if i do i dont think i would wanna be the one messing with that because i have never worked with either before..
    bondo isn't too bad man, in fact i just finished sanding my bondo'd up dash piece and am waiting for the primer to dry heh. Basically you let it dry and sand it to your liking. you cant screw up really cause its easy to take off and reapply. anyways, i had a double din and i just took a few pieces of balsa wood and put them in between the edges of the lilli and the dash panel thingy and superglued/epoxied the lilly in there. now its stuck in there pretty good . after that i filled in the gaps where the wood wasn't flush with bondo, and then sanded the front part of the lilly down a bit where it sticks out. then bondo/sand, bondo/sand and after you do that use the really thin bondo, its orange and i think its called spot filler or something, dunno. and then paint it...not bad really, i'll post pix when mines completed.
    May 2004
    thanx grayscale
    so what im gettin from bondo is i need to put it on a certain place so i can put it in the dash if there is a big gap from the screen to the dash. ok.
    ok so i have to buy a small or mini pc to store in the glovebox and run the wires to the lilliput i got that so far
    so what type of problems i might run into since im a newbie at this? and what solutions?
    Hayling Island, UK
    cooling and power
    power people recomend a DC-DC supply (opus are good, but they are pricy).
    DC-DC supply is basicly a ATX supply that runs of 12v
    Cooling in the glovebox, put some sort of extraction/vents to stop overheating.
    Hayling Island, UK
    Bondo + screen
    heres some info i found while the forum
    Xenarc + Bondo + Paint + One night =
  1. New widescreen panel Need help!
    By outragis in forum LCD/Display
    Last Post: 11-19-2003, 06:10 PM
  2. New Car Computer Noob Need Help
    By johnyeros in forum General Hardware Discussion
    Last Post: 07-26-2003, 07:14 PM
  3. NEW VGA Touchscreen? Need some ideas.
    By dscustoms in forum LCD/Display
    Last Post: 06-29-2003, 01:58 AM
  4. New To The Scene And Need Help
    By dirtythird in forum General Hardware Discussion
    Last Post: 04-13-2003, 09:52 PM
  5. New MP3 Car Radio - Need YOUR Ideas
    By mp3designer in forum General MP3Car Discussion
    Last Post: 01-25-2001, 09:23 AM
