Results 1 to 2 of 2
Thread: Lilliput Touchscreen LCD/M10000
    May 2004
    I have been looking at the Lilliput 7" touchscreens on Ebay and I am thinking about purchasing one. I have a question though. From what I have read the touchscreen works through USB, will this function like a normal USB mouse? Or are special drivers required? Also has anyone tried installing FreeBSD on an M10000? I am wondering if all the hardware functions well under FreeBSD.
    Newbie OrangePeel's Avatar
    Nov 2003
    Wellington, New Zealand
    They do not act as a USB mouse as far as I'm aware. They need to be calibrated, and although I think this is stored in their EEPROM, I'm not sure that it gives the screen mouse compatibility. Windows certainly doesn't attempt to install it as a mouse.
    There are binary drivers for various Linux distros, say here http://www.egalax.com.tw/Download.htm
    But I don't think any *BSD stuff is out officially. I just did a quick search on the FreeBSD hardware forums, and no mention of touchscreens there either.
    I have seen various mentions of Linux kernel support for various touchscreens, too. The actual USB resistive touchscreen interface is probably not specific to Lilliput (I have a Xenarc and I'm using the newer Lilliput-compatible software).
    So yeah. By the way, why would you possibly want to run *BSD in your car?!? You should probably just drop your l33t pride and just use Linux
    89 Celica, CarPC installed, 1st bday :)
    http://www.fishy.net.nz/carpc/
    • MediaEngine
    • Epia V8000
    • 80GB WD 7200RPM HD
    • Xenarc 700TS
    • SB Live
    • Opus 90W
    • CIMR100 remote
    • Deluo serial GPS
    • D-Link USB radio wired to power antenna
  1. No Signal on Lilliput 7 Inch touchscreen.
    By SuperDave01 in forum LCD/Display
    Last Post: 05-04-2008, 10:36 AM
  2. Lilliput touchscreen problem
    By samc in forum Input Devices
    Last Post: 05-09-2004, 12:12 PM
  3. *****ing lilliput touchscreen
    By mrzigzag in forum LCD/Display
    Last Post: 04-13-2004, 03:31 PM
  4. Replies: 1
    Last Post: 04-11-2004, 09:12 AM
