Sounds like you have a switchable output on that PS, check the output with a voltmeter. Mine was 18v and i had to buy a small 12/18v stepup inverter.
Good Luck
Hi
I want to create a carputer to play MP3s. I have a spare laptop with a broken screen, so that's a good start. I was wondering if I need a new power supply, or whether I can use the existing one. The connection from the mains has the usual box inline (I'm assuming it's a transformer), and it says on the back:
AC Input 100-240V ~1.2A Max. 50-60Hz
Fuse rating F2/250V
DC Output 14-22V 45W max
Or 8-20V 2.2A
For indoor use only etc etc.
The range of voltages is quite high, but they seem in the right sort of range. How can I find out whether i's safe to just wire up the car battery as a power supply?
Cheers
Duncan
Good Luck
Dual Lilliput's 70NP/C/T
Syntax SV266AD KT266A
AMD Athlon XP 2000
Viking 256MB DDR
D-Link Wireless 802.11B
Seagate 120GB
OrbitMicro 250W DC/DC converter
SII Wireless Audio Link
Digimoto OBD-II
Earthmate GPS
BU-303 USB GPS
D-Link Bluetooth
