If you place the magnet close to the hard drive or a floppy disc, yes it will erase it, and possibly damage it. I would place it as far away from the sub as possible to keep it from getting jarred from vibration.
will the magnet mess up my comp and will the vibration mess up my hard drive or anything
The power of a magnetic field depriciates as a function of 1 / r^2. Even if you were to rub your hard drive against the magnent on the sub, it is very unlikely it would damage anything (floppy disks are a different story because they are far thinner). Unless you plan on mounting your hard drive to the sub's magnent, your safe.
I know people on this forum before have mounted their computers inside sub boxes, and as far as I know, they havn't had any problems. You should be fine.
make sure everything is mounted nicely. I've had a lot of problems with my subs rattling the video card out of place
Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
Head units are for cheaters!
sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
Hard drive magnet is not a problem, looks for Leslie's setup, he's got it right close, not a problem.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
its something i worried about when planning my install, but dont worry about it.
Ive got a JL audio 12w6 in the boot about 1 foot away from the carputer, it doesn't do jack to it even up full.
Regards
John
Originally Posted by dank_Army
I was thinking about the JL audio 12w6 for my setup. What type of amp are you using to push it, and how is the quailty. I only need one 12 inch, because the other speakers should compensate.
Has anyone seen a need to protect the hard drive from outside vibrations, such as speed bumps not too fast but not to slow? Or when climbing or leaving a curb?
Good information to know. Thanks. Anyone got a reply to kdunn's comment about vibration. The only thing that I can think of is mounting it vertical to prevent platter crashing.
EDIT: Since a sub won't damage the drive I guess it's safe to assume that a 80 or 120mm fan won't hurt it either...?
Derek
Couple 80mm or 120mm fan's definitely won't hurt. Damage due to vibrations are probably the worst offender for killing HDD's in CarPC's. (Short of getting into a high-speed accident while changing MP3 playlists).
