Results 1 to 10 of 12
Thread: Is this bad? - extending vga cable upwards of 25 ft
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    Are there any negative things i have to worry about when extending vga cable upwards of 25 ft? Also whats the best way to get usb2 cable to go lengths of 15~20ft?
    bsc
    bsc is offline
    Newbie bsc's Avatar
    May 2004
    Norway
    The image could become blurred depending on the cable and how high frequencies you pass through it. It could also be perfectly acceptable.
    USB 2.0 works fine on 5m long cables in my truck. If you need more you can use hubs.
    EPIA CL-6000E mobo powered by 12V 55W PSU
    Creative Audigy 2 NX
    Samsung 152V 15" LCD panel (VGA, 1024x768)
    Aug 2003
    I had my 25' plugged into my 6' and it certainly was blurry..
    I have yet to try the 25' alone. I'll try to post a reply when I do.
    May 2004
    Boston, Mass
    blurry is bad. is there anyway to boost the signal? I have to run from my dash to my trunk. By my calculations I will have to use anywhere from 14-18 ft. I just throw 25 in there as over kill.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    the higher the frequency the shortest you can have to keep the parallel signals good.
    If its blurry, try a lower refresh rate, it might help you out.
    -Mars
    May 2004
    Boston, Mass
    ^^Thanks a lot.
    Feb 2004
    Montreal
    USB is serial, so in theory you could have a 2 miles cable and it would work.
    -Mars
    Mar 2004
    Vancouver, BC, Canada
    I'm using a 15' VGA with no problem. I believe the USB protocol is only designed to go about 12'. Do a search on "active USB extensions". An active USB extension is just a one port USB hub. www.cablesforless.com has USB 1.1 active usb extensions, www.expansys-usa.com has USB 2.0 active usb extensions.
    May 2004
    While USB is 'serial', the length limitations comes from that fact it uses DC (direct-current) of 0VDC to +5VDC. Old serial (RS-232) uses much higher voltages and a peak-to-peak of -15V to +15V to signify 1's and 0's. The range for a '1' is -5VDC to -15VDC and '0' is +5VDC to +15VDC. That's why serial runs could be 50 feet. You could induce up to a 10VDC drop in the line and the electrical 'bits' could still be read by the receiving ends.
    Back onto the subject, the longer the VGA cable, the more high-frequency signal-loss you're going to have. It is, of course, more evident as your run higher bandwidth/higher resolution. Best bet is to either, #1. Go DVI-D if at all possible or, #2 buy the best shielded VGA cable extension you can buy that's relatively thick and don't run it along anything that generates EMI. (i.e. AC lines). Hope this helps.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Or buy a VGA splitter/booster. I have this one from startech.com works great. Got it for $15 on ebay, retails for $106.99!!! http://www.startech.com/ststore/item...r=topbarav.htm
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
  1. VGA cable problem on DWW-7VGA, need pictures
    By OzPaddy in forum LCD/Display
    Last Post: 03-16-2004, 01:34 PM
  2. Vga to Svideo cable?
    By si2001 in forum LCD/Display
    Last Post: 11-01-2003, 01:33 PM
  3. Mounting my Datalux and VGA cable question
    By gfoulks in forum LCD/Display
    Last Post: 08-26-2002, 11:35 AM
  4. 25' VGA cable, possible?
    By InFix in forum LCD/Display
    Last Post: 05-16-2002, 05:34 PM
  5. VGA LCD Quality with long VGA cable?
    By vikrampant in forum LCD/Display
    Last Post: 01-11-2002, 12:02 AM
