Results 1 to 4 of 4
Thread: Size and Mounting Questions
    Constant Bitrate Katya's Avatar
    Jan 2004
    NoVA
    Question Size and Mounting Questions
    Hi,
    After having my car stereo stolen last month, I've decided to stop playing w/ the idea and just build a carputer. I've got a 2003 Mazda Protege5 w/ a doubledin space. I'm planning on using a 7" Lilliput screen, Panasonic CW-8123 DVD/CD-RW Drive, Opus 90W (probably) and I'm playing w/ using a Travla C134 case.
    My question is this. I believe my space dimensions are ~7.5 x 4.2 x 7. I'm trying to keep everything in the dash, if possible. Does anyone know if the computer will fit behind the screen and then mount the DVD/CD-RW below the screen? I've got another bezel to play w/, so I can bondo and cut into that as needed. Also, if there isn't enough space just in the head unit space, how about if I take over the HVAC space as well? I can control that using the carputer, if necessary.
    Thanks for your help
    Here is a visual, if that will help.
    Mar 2004
    Maryland/NOVA
    that is a great space to start with.
    i wish my bezel was like that.
    i have to make on from scratch because the platic surrounding the radio is all one piece.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    Jun 2004
    Baton Rouge
    I'm building my carputer for my protege5 as well. I've measured, and I'm pretty sure that with my setup (ITX board, full-size hard drive, opus 90w), that it won't fit behind the screen. Personally, I'd rather have my carputer attached to mine back seat anyways. I would measure to see if your setup would fit though.
    As for mounting the screen, it fits nearly perfect in the double DIN space, just a little cutting necessary. Here is an example of one that has been molded into the dash. (I think the screen is a xenarc, but nearly the same size) http://www.mazda3online.com/images/jaisai.jpg
    Jan 2004
    NoVA
    Actually, I've thought some more and I think I might go without a case or a custom case. I'm probably going to go w/ the VIA EPIA-M10000 board and laptop hard drive. I'm trying to keep everything as small as possible. Possibly skip the Opus too if I can. I'm not concerned too much about the screen size because I do have an extra bezel to play w/, but rather fitting everything behind it. I'm going to try and get some exact measurements this weekend and compare those to what I want to fit in there.
    I use my back seats and my hatch quite a bit, so I don't want to give those up. Also, I autocross, so I don't want to have to remove it for that. I want to see how sleek I can make it. No mouse, unless I end up getting a GPS mouse and I don't plan to use a keyboard either. I'll probably stick a USB hub in the glove compartment and attach a card reader to it, but that's all that I want to have outside of the dash. I want it to look sort of stock, and not easily removed.
  1. mounting a miniITX mobo
    By lummox in forum General Hardware Discussion
    Last Post: 02-11-2004, 05:27 PM
  2. NewB Questions for Laptop Install
    By PaulDePimp in forum Newbie
    Last Post: 02-09-2004, 11:57 PM
  3. DIN size
    By bombboyer in forum General Hardware Discussion
    Last Post: 10-31-2002, 07:53 PM
  4. some questions for TFT LCD screen
    By felix99 in forum LCD/Display
    Last Post: 06-12-2002, 11:20 AM
  5. Million $ Questiosn: HD screw size and wahz a good PC DVD player?
    By Tony S in forum General Hardware Discussion
    Last Post: 05-05-2001, 02:31 PM
