Results 1 to 3 of 3
Thread: Itps
    May 2004
    Itps
    i have used the handy search features of this forum and have got some info on what it does.
    I see that the ITPS is a controller that bacically turns on/off the pc depending on the ignition ON/OFF (powering down after X seconds)
    and regulates the 12v.
    But what if you dont want to turn the pc on when the car starts up???
    What i was thinking for my setup is that
    a) the Power on Button for the pc to be placed on the front dashboard.
    (gives me the option to turn on / off the pc)
    b) a seperate switch to power the amps (remote wire's 12v) *i want the pc to come on before the amps*
    im using a second battery in the back and a dc-dc psu.
    (batteries connected to each other, to maintain charge)
    i know that the ITPS regulates the power at 12v dead, to avoid power spikes.
    (can i use that feature only, and not use the startup/shutdown controller).
    + how does the ITPS connect up to the pc, ignition. i cant find any online manuals.
    thanx!
    Elsewhere
    Quote Originally Posted by Azh2004
    thanx!
    If you use the DC-DC PSU (such as the Opus) you don't have to wire it to the power jumper on the motherboard, and wire up a power button instead.
    I've read enough to know that running a standard power supply with an ITPC isn't as reliable an option. However, in your scenario, the start/shutdown controller wouldn't be needed. Mind you, your PC is either going to stay on when you turn off the car (thus draining the battery) or it's going to shut off with the car. The controller is to allow the PC to do a proper shutdown when the key is turned off.
    How about the Wiki?
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    thanx!
    You can just leave off the connection from J2 to the Sys Board.
    ITPS and PW-70a wiring pics
    Doesn't seem like you can do that with the Opus though...
    Troubleshooting 150W Opus (turns off after 20-30 mins)
  1. ITPS problems
    By numberone in forum Power Supplies
    Last Post: 10-29-2004, 05:07 AM
  2. Changing my position o the ITPS
    By adamis in forum Power Supplies
    Last Post: 04-24-2004, 08:13 AM
  3. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
  4. ITPS and PW-70: What turns it on?
    By dug1967 in forum Power Supplies
    Last Post: 02-15-2004, 08:22 AM
  5. ITPS Power Sequence review
    By saito in forum The Review Palace
    Last Post: 12-18-2003, 10:26 AM
