Results 1 to 3 of 3
Thread: Lilliput buttons relocated
    Constant Bitrate Rith's Avatar
    May 2004
    P'cola, FLA
    Arrow Lilliput buttons relocated
    Ok guys, im working out the final bugs before i buy all the parts, and i thing i noticed is that my dash is double din sized, which it only 4" up and down. Which means I can only fit the screen in the dash, but i have space on the left and right size for the buttons. Is it simple (or even posible) to relocate the buttons to the left or right side without alot of modding?
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    IIRC, the ribbon cable isn't quite long enough to move the buttons to the side. If you can find a longer ribbon, that might be the easiest solution. The other choices is to make up your own ribbon and/or extend the buttons with wires. Truthfully, you can do without the buttons.
    What I did was move the buttons to the back side of the screen (i.e. I cannot use them). I unsoldered the IR receiver and soldered a 2 pin connector in it's place. I then created a short cable (about 12 inches) and connector and attached the IR receiver. This lets me position the IR receiver in a convenient place so that I can use the remote to control the screen features, when/if needed.
    May 2004
    P'cola, FLA
    Thanks for the advice. I hope I dont end up blowing something up when i take it apart though
  1. WTB: BROKEN Lilliput 619!
    By masch in forum Classified Archive
    Last Post: 12-14-2004, 04:58 AM
  2. Running Lilliput w/out buttons
    By 59fire in forum LCD/Display
    Last Post: 05-28-2004, 02:48 AM
  3. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
  4. WTB: Lilliput Buttons
    By antimatter in forum Classified Archive
    Last Post: 03-17-2004, 01:53 PM
  5. Where To Buy Buttons, Switches, Lights?
    By eCar™ in forum General Hardware Discussion
    Last Post: 02-22-2004, 03:25 PM
